Hi am holding one printer wep HQ1600 highspeed dmp printer in this showing set paper again message again & again.paper is loaded in rear tractor and i have confirmed all sensors.there is no paperjam atall.it taking the paper smoothly whenever i press the load eject button but instantly shows set paper again message.please advice me the solution for this .praveen.ss guwahati
Hi sir good evening
Posted on Jun 20, 2013
  • sakhtivel
    sakhtivel Nov 10, 2013
    i have solved that issue by replacing the 8 pin cable which is connected in b/w the l/c and the connector placed in the carriage block
Set paper again error message & fuctional error5
Posted on Jun 30, 2014
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Our printer is flashing Tractor1 tear. We are not able to print nor can we get this to quit flashing. I have tried turning it off and back on still having the same issue. Help?
The "Tractor 1 Tear" message is not a error as such, this is an information message showing the printer is set to the front tractor feed (tractor 1) if you press the button directly under "Tear" the printer should move the paper to the tear possition.
If the pritner is not printing I would recomend checking the following;
  1. Ensure the printer is set to "ONLINE" press the button you should see ONLINE TRACTOR 1 TEAR on the display
  2. Ensure the printer is loaded with paper, press the button under "Tear" the printer should move the paper forward if it is loaded into Tractor 1.
  3. If you are not using Tractor 1, ensure you select the paper path you are using within the menu and move the paper selection lever.
  4. Observer the LCD display for any errors that may be seen when print jobs are sent.
  5. Try printing a menu print on the printer this will identify if the printer will print, the menu can be printed in the following way.
    -Power the printer ON holding down the button, keep the setup button held down whilst the printer initializes.
    -When the printer has finished initializing ensure the printer is OFFLINE
    -Press and release the button to enter the MENU
    -Press the button under "MENU" on the LCD display
    -Press the button under "PRINT" on the LCD display
    The printer should print a menu settings page, if this prints OK the most likely causes for the problem are;
  1. The computer system is not sending jobs to the printer (check the correct printer is selected on the computer system)
  2. Connectivity problem (check cabling, IP Addresses etc)
  3. The wrong printer driver is being used
Mar 04, 2011 | Tally T2240/24 Matrix Printer
I have Epson LQ 2180. When Ever i load paper from rear tractor feeder it loads the paper and still shows the paper out LED. If i press Load/Eject button it only loads the paper not eject. I have cleaned...
Hi
My friend we have LQ2180 in our office, there i a lever in the right side of the printer that indicates when you print your document. Adjust to upward to print the document from rear tractor and to print from the front push the lever downward. Maybe you accidentally, push down the lever.
Any problem, just message me. Regards.
Jan 11, 2011 | Epson LQ-2180 Dot Matrix Printer
Printer is not printing with these pages alternating"online single load" and "load paper from single"
The printer is indicating that the paper path has been changed (either via the control pannel on the printer or by escape command) to the single sheet feeder.
I guess you are using Continuose Paper fed into the tractors at the front of the printer (Tractro 1), if this is the case you need to go into the menu on the printer and change the paper path back to Tractor 1.
Press the Setup key
Select Tractor 1
This should change the peer path to the front Tractor, if this does not work power the printer OFF and disconnect it from the computer system. Then power the printer back on again and again try changing the paper path as described above.
If you get the message LOAD SINGLE only when you send data to the pritner you need to check the paper path selected on the computer system.
Jan 25, 2010 | TallyGenicom 2280 Matrix Printer
Eject Error message
I would suspect that the paper path has been changed via the control panel. If you are using continuous paper fed in from the tractor this should be Tractor 1 (unless you have optional tractors).
If the printer shows something like SINGLE on the display, it is for sure that the paper path has been changed.
Disconect the pritner from the computer system, and power the pritner off and ofter 10-15 seconds power the printerback on again.
  • If the menu shows as locked power the pritner on holding down SETUP to unlock the menu.
    Nov 18, 2009 | TallyGenicom T2265 Matrix Printer
    Printer screen message reads turn paper lever then online single Can't get it to print
    I guess you are using tractor fed paper, the type of paper with holes down the side.
    The problem you have is that the paper path has been changed on the printer to the single sheet feeder rather than the tractor feed, you will need to change this back again via the control panel, this is done something like this;
    1. Put the printer Offline
    2. Press Setup
    3. Press the button under PaperWay
    4. Change this to Tractor 1
    5. Press SET
    If the above steps do not work disconnect the printer from the computer then try again.
    For more info see the Dascom web site;
    http://www.dascomeurope.com/support2/technical_notes/serial_matrix/T2240/T2240_tn007.htm
    And look for the Online Single & Load section
    Oct 14, 2009 | Tally Serial Matrix T2130 Printer
    Out of paper error message but printer is loaded with paper.
    Please follow the follwoing steps,
    1) Open the rear access door and check for any paper jam and struck paper, unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
    2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
    Regards,  raj_p5983
    Jan 22, 2009 | HP Officejet 7210 All-In-One InkJet...
    Show the load paper error
    There is a paper motion switch behind the tracter feed assembly that might be stuck. Check that and also clean arround the tractor assembly.
    Jan 01, 2009 | Printronix Line Matrix P5005B Printer
    Printer setup
    Continuous forms paper fed through the front of the printer also uses either the Front Push, Rear Pull, or Push-Pull tractor configurations. Make sure this is set correctly or it will reverse your margins.
    It could also be your software. When you print through windows it's using the Microsoft system font controller, but your software could be setting font, margins, and alignment by the settings in the printer not in the driver. So if the first doesn't work, set your system back to align left then go into the printer configuration menu on the device and adjust the margins there.
    Dec 15, 2008 | IBM 4247 Model V03 Matrix Printer
    367 people viewed this question
    jasbo
    jasbo
