Question about Hampton Bay 40106 Minute II Ceiling Fan
I saw a minuet II with a remote at my friend's house. My friend said he is not the one who bought it. I want one in my small kitchen with a remote. I can't find one with the remote at any websites. I look at about 20 websites and I can't find 1 with a remote. I looked at the sticker on top of that motor, and it said 40106. I looked that at a website and it said "remote: no". I looked at the review and none of them have to do anything with the remote. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • AsshoIe Jul 15, 2010
    I replaced it with dimmable CFL bulbs.
  • 677 Answers
Hi, have searched through the internet over and over , couldn't find the one with remote.
You can find out through your friend. By getting the website of the particular minuet you saw in is house and get the particular one you are looking for.
Take care.
Posted on Jul 14, 2010
  • 4 more comments
  • AsshoIe Jul 14, 2010
    I asked hampton bay company and they said that they never ever made one with the remote. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • ikechukwu joshua
    ikechukwu joshua Jul 14, 2010
    Going to the company and they said they do not do such , That means it might be a universal remote that coincidentally worked with it.
    I bought minuet II from home depot and I also bought remote control kit. I installed it with the remote, and when I tested the fan, There are 2 problems. Wobbling and making clicking noise, and flickering CFL bulbs. I need help with these.
  • ikechukwu joshua
    Many problem issues associated with Ceiling Fans can be attributed to
    the installation, and are easily corrected. Below is a general overview
    of the more common things missed, or
    done improperly when installing a Ceiling Fan. If you have more
    specific questions about the operation of any ceiling fan. Please
    contact us 952-898-2754 or 1-866-60-FANS(3267). With over 20 years of
    experience in Ceiling Fans and Lighting. "Our knowledge is Free!"
    Other
    helpful information: Ceiling
    Fan Facts
    , Casablanca
    Intelli Touch Diagnostic
    , Casablanca
    Flywheel Repair
    , UC7067RC
    universal remote receiver
    Noise
    Motor size is the key to quality. Over time,
    it is not uncommon for smaller motors to develop sounds that are
    unrepairable. Below are a few tips that may help determine if that is
    the case.
    Switching: The use of a dimmer or
    rheostat wall control on the motor will cause any ceiling fan to "Hum".
    Ceiling Fan motors need to be run from a switch that has set speeds. SW95
    or SW90
    are switches that will work with most brands.
    Mounting:
    Anything not tightened properly may result in amplifying any sounds the
    ceiling fan might make. Make sure all screws and light fixture glass
    are tight.
    Wobble
    It
    is considered "Normal" to have a small bit of motion in any Ceiling Fan
    running on high speed. Blade balancing kits included with most ceiling
    fans, can reduce or eliminate this type of motion. Below are a few tips
    if the ceiling fan wobbles excessively. The easiest test for loose or
    poor mounting; Give the bottom of the
    ceiling fan a light push with your finger. On stem mount fans it should
    come back to center and stop. If the fan keeps moving, follow these tips
    for excessive motion.
    Mounting: The electrical box
    in the ceiling needs to be metal, and securely mounted to a joist or
    brace kit. The mounting bracket from the ceiling fan must be tight to
    the electrical box.
    Down rod or Stem: On ceiling
    fans with a down rod or stem. Make sure the groove on the ball at the
    top of the stem is aligned with the notch on the mounting bracket. There
    are usually multiple set screws to tighten at the ball and where the
    stem mounts into the top of the ceiling fan.
    Blades:
    Ceiling Fan blades are matched sets, weighted within a gram of each
    other. Loose or warped blades can be a cause of wobble. Make sure all
    screws holding the blades to the irons, and the blade assembly to the
    motor a tightened properly. To determine if you have a warped blade or
    bent blade iron: Use a ruler to measure from the tip of the blade to the
    ceiling. Let the blades pass by the ruler to see if one or more is
    higher or lower than the rest. There can be a slight difference in
    height that will not cause any wobble issues.
    Operation
    Ceiling
    Fans that stop working, or fail to operate when first installed may
    need check a few basic things first.
    Wiring: Make
    sure there is power to the ceiling fan and the wall switch is in the
    "On" position. Follow the wiring instructions included with the fan and
    double check connections.
    Switch housing: The
    switch housing is the bottom portion of the ceiling fan where the light
    is attached. Move reverse switch to one side or the other (stuck in the
    middle makes fan inoperable). Make sure any plug connections are
    properly inserted. Check either side of plug connections for any wires
    that are loose or pushed out of the plug.
    Wall Switch:
    When using a wall switch make sure the pull chain on the motor is set
    to the highest speed.
    Smell or Odor: Ceiling fans
    that give off a bad smell, typically need a new capacitor. Call us for
    identification
    Remote systems: Make sure the
    receiver and transmitter are set to the same frequency, and wired
    according to the instructions.
    I fixed the wobble, and I still need help with flickering.
  • ikechukwu joshua
    ikechukwu joshua Jul 15, 2010
    How to Fix Flickering Lights
    We've all experienced it. The lights flicker for no apparent reason,
    sending the kids into tales of mysterious ghosts lurking in the corners
    of the house. Chances are there is a very logical explanation for
    lights that flicker on occasion. So before you call in the ghost hunters
    or fork out the money for an electrician, there are a few simple things
    you can check on your own to determine the cause of flickering lights.
    Check the lightbulbs to be sure they are not
    loose in the socket. A loose lightbulb will light intermittently,
    causing lights to flicker off and on at times. Tighten the bulb to see
    if that takes care of the problem. Check that you are using the proper
    size bulb for the socket. Some lamps require specific bulbs.
  • Step 2
    Change the bulb if the problem persists. Occasionally, a bulb
    will flicker before it goes out completely. The problem may simply be a
    bulb that is about to burn out.
  • Step 3
    Inspect the electrical cord carefully. Unplug the lamp and
    check to see if the plug is loose. A faulty plug will make intermittent
    contact with the electrical supply and cause flickering lights. Check
    for any breaks or worn areas on the cord. Replace the lamp or have
    someone with experience in working with electrical cords replace the
    cord for you. Never attempt to replace cords on your own if you are not
    sure of the proper procedure and safety precautions.
  • Step 4
    Examine the outlet itself. Plug another appliance into the
    same outlet to see if it functions properly. A hair dryer or CD player
    is a good choice, as it is easy to determine if it is functioning
    properly. If the outlet is faulty, you will need to call an electrician
    to fix it.
  • Step 5
    Observe other appliances
    in the home to see if they are receiving full power at the time the
    lights are flickering. A problem with the electrical supply to the home
    will likely cause all electrical appliances to receive intermittent
    power. Depending on your area, it is common to notice brief
    interruptions in the electrical supply on windy or stormy days.
  • Step 6
    Call an electrician if you are unable to determine the cause
    of the flickering lights. There may be a problem with the wiring in the
    home that requires the services of a certified electrician. Be specific
    when describing the problem, providing the electrician with the
    information he needs to troubleshoot your difficulties.
  • Read more: How
    to Fix Flickering Lights in the House | eHow.com
    http://www.ehow.com/how_5022684_fix-flic...
    Change the bulb if the problem persists. Occasionally, a bulb will
    flicker before it goes out completely. The problem may simply be a bulb
    nspect the electrical cord carefully. Unplug the lamp and check to see
    if the plug is loose. A faulty plug will make intermittent contact with
    the electrical supply and cause flickering lights. Check for any breaks
    or worn areas on the cord. Replace the lamp or have someone with
    experience in working with electrical cords replace the cord for you.
    Never attempt to replace cords on your own if you are not sure of the
    Examine the outlet itself. Plug another appliance into the same outlet
    to see if it functions properly. A hair dryer or CD player is a good
    choice, as it is easy to determine if it is functioning properly. If the
    outlet is faulty, you will need to call an electrician to fix it.
    Call an electrician if you are unable to determine the cause of the
    flickering lights. There may be a problem with the wiring in the home
    that requires the services of a certified electrician. Be specific when
    describing the problem, providing the electrician with the information
WHAT TYPE OF REMOTE DO I USE FOR A HAMPTON BAY CARRIAGE HOUSE II 52 INCH CEILING FAN WITH LIGHT
If it was an add-on remote, then you probably can use any remote. If it came with a remote ,then you must find out what kind of receiver is in the fan.
Sep 07, 2013 | Hampton Bay 52 In.Carriage House II in...
I have a Humax PVR 9300T with a RT-531B remote. Suddenly the remote has stopped working although the batteries in it are fine. What can I do to fix this?
from "sceptical Glenn". I had the same problem & saw solutions so thought why not!!!.unplugged box, removed batteries,waited 10 mins.Held down "ON" button for a good minuet.Pressed all buttons from top left to right all the way down"like reading a book" even the ones under the slidey bit.Replaced batteries pressed buttons again in the same sequence,plugged the box back in pointed remote at box held "ON" button down for another minuet, then crossed my fingers.Pressed a button and it worked,"Wheay" success it worked it worked.Never again will anybody call me sceptical Glenn again.Thanks for the solution I am now a happy remote control using person once again, never having to leave my settee again only for a beer,or the loo or food,but that can also be rectified as I sit near the window...the pizza man can pass it through to me.
Dec 14, 2011 | Televison & Video
Just bought Skill Saw 5150 with no blade and bought a 7 1/2'' blade and the saw has a wrench but can't find anyway to lock to undo the nut so I can replace the blade. I pulled on trigger and held it but...
hello I can help you. Look carefully around the housing that surrounds the blade and you will find a small lock button. Push it in and rotate the blade until it locks. Then apply the wrench.
here is the link to the free manual from skil
http://www.skiltools.com/en/CustomerService/PartsListsOwnerManuals/
Jun 17, 2009 | Saws
Hunter ceiling fan with remote will not reverse.
I was puzzled too... here's my fix... the remote has six buttons, the very small one at the top is the reversing button. Remote is part # 85095. It's a Westside II fan, bought at Costco.
Jun 16, 2009 | Hunter 52" Ceiling Fan With Light And...
REPLACEMENT COST OF MAGIC CHEF ELECTRIC RANGE MODEL 6898XVB
you should be able to buy one for between 400 to 600 dollars new.i would check lowes or home depot to see what they have in stock.
Jan 13, 2009 | Magic Chef CES3760 Electric Kitchen Range
AudioLogic DVD-108 - help setting up component cables (no picture)
This may not be a solution, but is a good start. I recently bought a house with the theater system installed, but no remote. Had similiar problems with some functions on Universal remote. Did a google search and got the remote for my system and presto! I did a google on the DVD-108 and saw a AudioLogic remote(similiar, Originals are no longer available), and saw that there is a "setup" button as well as others that may select inputs. This may not be a solution, but would be a good start. Worked for me!
Jun 26, 2008 | Audiologic DVCR-251
Concept II
Depending on what year the fan was made try looking very close at the actual body of the fan. you may find a small switch you can manually use to reverse the direction of the blades.. I may have some used working remotes that will work with your fan if you like please feel free to contact me at payitforwardx2 @ gmail . com .
Jun 08, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Hampton Bay Carriage House II
I went ahead and hooked up the wires, and then zip stripped the wireless receiver to the side of the motor mount. Works fine and fits inside the canopy (motor cover).
May 30, 2008 | Hampton Bay 13087 70450 Carousel II...
32inch Akai tv
contact your friend and ask for the code! if not, look in the manual and try to fix it. =]
Nov 15, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Open Questions:
See all Hampton Bay 40106 Minute II Ceiling Fan Questions
Hampton Bay 40106 Minute II Ceiling Fan Logo
48 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
