Question about Zanussi ZHF470 Electric Double Oven
The bottom oven on my Zanussi built underoven is not getting hot. model no. ZOU 575 N ser.no. 81100001
  • John Wilkinson Jul 18, 2010
    make sure you have set the time of day on the timer. try the oven on a different mode of cooking conventional instead of fan or vice versa. if it works in a different mode then the element(s) have failed in the mode you usually use. If its not working in any mode i would need to know if the oven light is on. /temp indicator lit or not/ on fan mode whether the fan runs or not/ In the grill mode for the top oven is the cooling fan blowing out of the vents across the handle.
  • 1462 Answers
SOURCE: ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Posted on Oct 01, 2008
SOURCE: zanussi zuf270x main oven not getting hot
I've just mended this myself and it took about 15 mins:-)
It's more than likely the heating element, you can get one off the internet for about £20 if you go for the electrolux replacement.
Open oven door and remove the trays, undo the four small screws on the back wall inside - not sure if you have to, but I turned the power off at this point. Better safe than not! Turn this around to the right wall as it won't come right out due to the bit of wire on the right (temp sensor maybe?).
If you've already got the new element you can guess what happens next; take out the 3 small screws holding in the element and gently pull towards you. It's attached to two wires poking out of two holes - take the bottom one off first as it seemed to have less tendency to fall back in the hole (I reckon that could be a real pain to get back).
Hold the wire still and wiggle the old element to remove as you will have less chance of damaging the wire that way. Reconnect the wires to the new element and pop it back together again.
Job done and after a year of waiting we now have double the oven space!
Posted on Jul 31, 2009
barkencoa
  • 3463 Answers
SOURCE: my oven wont get to temperature why?
If oven is getting hot , but not hot enough, then the thermostat is probably faulty.if no heat at all, then you need to replace the oven element.
Please rate my solution.
Thanks.
Posted on Sep 09, 2009
barkencoa
  • 3463 Answers
SOURCE: zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Thanks.
Posted on Nov 11, 2009
  • 417 Answers
SOURCE: zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Posted on Dec 26, 2009
Zanussi ZOU 91 K gives error E80
An error has occurred with reading the programme selector. This can be resolved simply by turning it to "0" and selecting a programme again.
Nov 30, 2013 | Ovens
Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
May 14, 2010 | Zanussi ZDQ495 Electric Double Oven
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
Bottom oven stopped working on my zanussi built in cooker model
If it is a fan assisted oven, and the fan is working o/k , then it is more than likely the oven element has failed.this is located at the rear of the oven behind a removeable cover.
Hope this helps.
Jan 10, 2010 | Ovens
Zanussi double oven ZDQ895 top of the oen is hot but oven will not come to temp bottom part of oven feels cool (fan oven)
If the fan is working o/k, then you need to fit a new oven element located behind rear cover of oven compartment.
Thanks.
Nov 15, 2009 | Zanussi ZDQ895 Electric Double Oven
Zanussi built-in oven ZDF 866W socket blows when turned on
sounds as if a wire to the fsd is shorting when oven turned on.
Sep 28, 2009 | Ovens
My oven wont get to temperature why?
Thanks.
Sep 09, 2009 | Zanussi Ovens
I want to replace the top grill element in a zanussi zhq 575
Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
Fit new element in reverse order, it is a fairly straight forward repair to do..
Plz rate my solution.Thanks.
Jan 03, 2009 | Zanussi ZHQ575 Electric Double Oven
Sep 30, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZHF470 Electric Double Oven Logo
145 people viewed this question
Top Zanussi Ovens Experts
ashburton
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
