Question about RTO 21.6v Kawasaki 4 Piece Cordless Power Tools Drill Saw
I have 8 Kawasaki 21.6v cordless drills Model 691220 they all have burned out power switch was there a recall on these switches and where do I find them
  • Lance John Jul 30, 2012
    I have 2 drills and both have problem with the power switch. Also all batteries are dead, where do I get replacement parts?
  • facebook651
    facebook651 Sep 12, 2012
    HI, I do have one. The switch burn down but got a replacement switch ($15) from the US importer (Alltrade tools LLC). Call 1-800-590-3723
  • 2,841 Answers
Are you sure the model of the drill is 691220? That would appear to be the model of the charger base. I know of no recall on the switches but I need the correct model # to be sure. There was a recall on the charger base for certain drills. http://www.consumeraffairs.com/recalls04/2007/alltrade.html
Posted on Jul 14, 2010
  • 4 more comments
  • pcaranci Jul 14, 2010
    Hi thanks for your quick reply tomorrow when I go back to the shop I will verify that number but one thing is certain the switches are all burned out I took one apart and where the main contact makes contact it has melted the plastic right trough, basically there is a hole burned right trough on 5 out of the 8 who carries parts for kawasaki in Canada or USA I will get back to you tomorrow with the Model #
    Thanks Mike
  • pcaranci Jul 15, 2010
    Hi Clay I verified the model # 0n this drill and it is 3076022 tell me where I can get the swiches for them and weather there is a recall there should be when 8 out the dozen that we bought all have the same problem Any help would be greatly appreciated
    Mike
  • NOT ME Jul 16, 2010
    Sorry I have looked and looked and can find no parts for this drill. There also is no recall on the power switch that I can find.
  • Joyce Heathco-Tatsch
    Joyce Heathco-Tatsch Aug 31, 2012
    I have the same drill, whick I loved. Model of the drill is 691220. It was working great and right in the middle of putting in a screwwed it just quit. It is possible that it is also the switch. I would love to fix it instead of buying a new drill.Please help. Everything else works, the light comes on the batteries are good. Twice when I pulled the switch it worked for about 10 second and quit again. s
  • dwalters5
    dwalters5 Nov 02, 2012
    I bought a pair of them and one has no serial # and when i put battery in it run one way and you could shut off then i open it and the switch is burnt through,after taken it apart and puting it back together it run 2secs and quit ,they are china junk, im calling to see why there isnt a recall on them because this is unsafe if i were you i would do the same call service Don Walters
  • dwalters5
    I bought a pair at a thrift store only one charger and when i got it home the one was locked in one direction and wondnt stop untill i took out the battery took it apart and found the trigger was burned through, so i will call the 1800 590 3723 o yes same model#691220 but in the case it came in it is model 840972
I need a trigger switch for my Kawasaki cordless drill 691220
there a possible answer here.
http://www.fixya.com/support/t5303722-8_kawasaki_21_6v
Jul 03, 2017 | kawasaki Drills
Drill began to smoke in the case
frist of all .there is no recall by Kawasaki on this unit!!!!!!!!!, if anyone tells you that there wrong. There are two units soled, one is green and black. this unit is for small home uses only, and its not for sheet rocking and or deck building. The other unit made, is a Little tougher. but steel for home use only, that one, is the black unit and sliver. the problem is over use of the unit, and using it, for what it was not designed for. The company that makes this unit is coming out with A higher amp switch. The company is (All trade) please use the unit for what it was designed for. Now to clare fy I'm A kawasaki engine and power service center, along with over 82 Manufacture and hundreds of products. this unit is not warranted by kawasaki bit by ALL Trade. thank you, good luck
Oct 01, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Same problem, switch has melted
check with kawasaki to find the problem. well get back
Sep 08, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Kawasaki 19.2 cordless drill
I will go one further, they had a recall of their batteries which could have led to your problem back in 2007 and the chargers on some of them also. I would again call the number and give them the date codes from both and then try again at getting it replaced. Their are a lot of posts online for this to be a simple occurence, The battery could have shorted internally causing the switch to melt and there would be a potential for user injury also. Let me know if you find anything out and if you have there web address I would be interested.
Jun 01, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Need a new switch for a cordless drill
what is the brand and model number of the tool?
Apr 28, 2009 | RTO 21.6v Kawasaki 4 Piece Cordless Power...
Hi Tim, Sounds like you got it figured out! The only question I see is if there is a quick fix, and it looks like you answered your own question. You can certainly pursue requesting that it be fixed as a manufacturing defect/ faulty part, or even a safety hazard as that is your right. While I can not suggest you take that route, the old metaphor of the sparking trigger that melted in my hand always seemed to get a lot of attention. Good Luck to you, hope this Fixsya!
Mar 13, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Re: Burned trigger switch: call the number on the drill (800.590.3723) and tell them what happened. They will offer to send you a new switch or have you send the drill in for replacement of the switch--although the person I talked with said they would probably just replace the whole drill.
Dec 13, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Kawasaki 19.2V Battery
Danger!!! There is a RECALL NOTICE in effect for batteries and chargers for Kawasaki 19.2v systems. Go to the website and check your model number and they will ship you a free charger, if your model number is affected, RECALL NOTICE
Jan 13, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Finger Switch
Call1-800-423-3598,give them your model number so they can send a replacment trigger assy.
Dec 08, 2007 | kawasaki 19.2V 4 Piece Cordless Tool Kit
RTO 21.6v Kawasaki 4 Piece Cordless Power Tools Drill Saw Logo
2,210 people viewed this question
Top RTO Drills Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a RTO Drill Expert? Answer questions, earn points and help others
