Question about Whirlpool Duet GHW9150P Front Load Washer
Wont start wash
Power is goin to machine red light is on door is closed properly settings r set but it wont start washing
  • Whirlpool Master
  • 8,220 Answers
Your tech sheet will give you diagnostics to performwont start wash - cac0abf.jpgd877420.jpg043e677.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 14, 2010
No red light on washing machine when I'm shutting the door to start a wash,why...
bulbs do go bad but if all functions work why worry about the red light .
Dec 02, 2015 | Washing Machines
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
Washing machine filled with water but wont start, the spanner, delicates sheets and high efficiency lights come on after about 30 seconds, what could i look for
Fisher& Paykel have a lot of controls. But if it's filled with water and the lights are on, you have power to the unit. Try unplugging it, waif 5 min. Power it up advance the setting to drain/ spin setting with the door closed and try it again. What do you mean the spanner ?
May 15, 2014 | Fisher and Paykel Aquasmart wl80t65c
Indesit Washing machine WIL88 red light flashing
Seems that the main board or the processor is hanging up and does not take up the full process control. You need to remove the panel and check for moisture on the board, check for loose connectors. If this seems fine the fault seems related to the board and can be confirmed with a board swap before one can be ordered. Check the door switch and wiring to the main board.
Jun 03, 2013 | Washing Machines
Why is F16 code flashing up on my bosch avantixx washer dryer
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Aug 26, 2012 | Bosch Logixx WFT 2806 Front Load...
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
142 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
