Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My kitchenaid superba refigerator will not cool
Will not cool. has power when plugged in. motor on. fan not running.
Check to see if the copressor is running - if not - probably the logic board....
Posted on Oct 29, 2012
  • 71 Answers
Try vacuuming/cleaning the coils behind the floor grill.
Posted on Jul 17, 2010
My kitchenaid ksrg25fkss refigerator supera wont get cold
freon. dirty coils under refrig. fan motor by comp. not working. make sure first of all comp. is running if not make sure freezer fan is. if that the case you need a relay starter overload or a compressor.
Apr 01, 2012 | KitchenAid Refrigerators
Kitchenaid model KSCS25INSS
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Jul 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Refigerator and Freezer not cooling
    You might try cleaning all the dust if any from the back or access to the bottom front.
    Feb 14, 2008 | KitchenAid Superba KSCS23IN Side by Side...
    My compressor cooling fan quit- the compressor still runs. I unplugged the unit then plugged it back in. The cooling fan ran for about 15 seconds, then shut off again. Is the problem with the main control...
    The problem is most likely the condensor fan motor is starting to fail. This is easy to check, First remove the back cover and when the compressor is running you should have voltage going to the fan motor if you do the fan motor needs replacing if not then the main board would be at fault here is a link that should help http://appliancehelponline.com/refercondenserfan.html
    Jun 23, 2010 | KitchenAid Superba Architect KSCS25INSS...
    Kitchenaid superba side by side top is too warm,
    The defrost cycle is suppose to be automatic on this model. To see if you have a defrost problem take the lower container out of the freezer, and empty the bottom shelves enough to see the back panel inside the freezer. If there is a build up of frost on the panel or the slots in the lower back panel the automatic defrost is not functioning. The most likely suspect is the ADC or automatic defrost control. This control runs about $120.00 and is located in the console of the fresh food section (top).
    If there is no frost check to see if the fan in the freezer is running. If the fan is not running you have a failure of the fan motor which is a little less expensive but a bit more challenging to replace, the shelves, the shelf slides and back panel of the freezer have to come out to replace this motor.
    Apr 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
    Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
    sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
    Apr 24, 2009 | Refrigerators
    Ktichenaid, freezer on top
    make sure your compressor is running if is not and and is just humming then is just your overload since you had a power outage it might off tripped it just repl and try that
    Nov 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Condensor overheated
    The reset should be automatic. If the fan is running now everything should return to normal after the fan cools it down.
    Jun 07, 2008 | KitchenAid Superba Architect KSCS25INSS...
    KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
    396 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    mike cooper
    Todd Arndt
    Todd Arndt
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
