Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
English instructions for saivod fhs186 ice maker
  • Scotsman Master
  • 8,220 Answers
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Posted on Jul 14, 2010
  • pmingetti May 31, 2014
    the olny adjustment on the cube sizer is on the float
English instruction for fryer Saivod FR-21 thank you, Janet
Sorry, you won't find any. That model has never been marketed in English speaking countries so the manufacturer has never gone to the expense of producing an English translation.
Your manual is most likely in Spanish, (but the answer is similar whatever it's written in) your fix options are as follows:-
1. Type in key parts of the text into automated online translator websites, try a few sites as some translate better than others.
2. Ask nicely among your circle of friends and relatives for a fluent Spanish speaker who may be willing to translate the important parts of the manual for you.
3. Pay a professional translator.
Jul 09, 2011 | Microwave Ovens
I need a manual in English for my Nemox Pro Gelato 6000 ice cream
You must register your product and request a new manual in english directly from them. You can do that directly at their site.
http://www.nemox.com/uk/dillers.html
Jul 22, 2010 | Nemox Pro 6000 4.23 Quart Ice Cream Maker
Need instructions
You get the instructions here, they are in three languages, right side is English :
Arctic Twister
Oct 15, 2008 | Black & Decker IC200 Arctic Twister 2.11...
NO instruction manual
Arctic Twister
Oct 15, 2008 | Rival Ice Cream Makers
Manual for ice cream maker
Go to this link:http://www.magimix.com/index.php?rid=60&cid=990&lg=502 and click on "Instructions for use" above the picture. Then download the pdf file. Its free and in English!!!
Enjoy making ice cream!!!
Jun 23, 2008 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Manual for nostalgics ice-cream maker
I found the manual able to be downloaded on multiple sites. Go to Google, type in the words old fashioned ice cream maker, and in the returns you will find links to web addresses that have these manuals available for downloading using Adobe. The original manuals in both English and Spanish. I didn't save the webaddresses, but I can assure you that they are there on Google. Don't type in Nostalgic Electrics Old Fashioned Ice Cream Server, just old fashioned ice cream server, and then go to the web address, it's the one that states they have the manuals for all ice cream makers, and type in the ICM-507 product designation or just click the available picture of the ICM-507. I will try and recover that web address and post it here. Found it! Here it is: www.pickyourown.org/icecreammakermanuals.htm I can assure you it is there! if you want the whole enchalada: www.pickyourown.org/icecream/Nostalgia%20%old%fashioned%20%soft%20serve%20ice%20cream%20maker%20manual%20ICM-562.pdf. And thats the real "skinny" for this model folks! Whew, you'll have carpal tunnell time you put all that in there. Kindest regards, Joe R. Downs Jr.
Dec 30, 2007 | Nostalgia Electrics ICM-507 Old Fashioned...
Kitchen Appliances - Others Logo
727 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
