Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
I am getting the pip but not regular picture. Sound no picture.
    Sergeant:
  • 252 Answers
It could be as simple as your remote going bad try useing the buttons on the TV to make your TV go from PIP to regular screen. If this solves it then its your remote. If not you could have a defective IC chip or switching device such as a transistor
Posted on Jul 30, 2010
How do you get screen full size. Picture is in top corner
Could be PIP (picture in picture) has been accidentally switched on.
Accidentally pressing the PIP button on the remote is something I used to do regularly.
Sep 09, 2017 | Televison & Video
No picture on main screen
Sets with PIP use two tuners--one for main and one for PIP---likely the main got hit with the static discharge during the storm----Here we always disconnect both power and cable when a storm.
There is a way around this (will lose PIP) with a cable box connected to the audio and video inputs on rear of set---bypass the tuners and use the box to change channels and provide signal.
let me know if questions.
Nov 07, 2012 | Televison & Video
Sharp CX80H6 Has sound, no picture for TV or AV OSD works
This style of failure with the CX80h6 and indeed other CX80 & SX80 series SHARP 80cm sets is usually due to problems with the PIP (picture in picture) sub-board. This small board plugs vertically into the main left hand PCB (seen from rear of set) and is sealed in tin-plate for RF shielding. I've had two CX80h6 sets recently with this exact failure and both had problems with the PIP sub-board. One needed a new regular on the board while the other had a dry joint on the connector. This sub-board is not available from SHARP anymore, but in most cases the failed component is a discrete that usually can be sourced in it's own right. So this sub-board is where I think you should start your fault finding.
Regards,
Romsey
Mar 15, 2010 | Sharp 32C-240 32" TV
No picture and sound but half screen pops up with pip
You probably have chosen the wrong input selection on your TV.
Sep 09, 2009 | Panasonic PT-47WX42 47" Rear Projection...
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
FV-27KV300 WEGA 27" Sound Problem
adjust the sound IF in the tuner or in the IFblock
May 03, 2008 | Sony FD Trinitron WEGA KV-27FV300 27" TV
Pip screen and tv screen wont produce a picture at the same time
Order a new TV....thats what I have to do. I have the Protron 42", and I cant get any sound, and I cant get the remote to work. Figures, too.....the TV JUST passed its warranty period by 4 days! I havent seen any positive things said about this company, either.
Nov 04, 2007 | Protron PLTV-32 Television
No pic/sound on main screen
I will recommend replacement of the main tuner
Dec 10, 2006 | Toshiba CN35F95 35" TV
TV has sound with no picture display
Is it possible the pip and the main picture have been swapp and the main picture is showing as the Pip?Is a possibility,check it out and let me know.
Sep 29, 2006 | Tatung V30DMTT 29.6 in. LCD Television
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
