Proline dvd 1260 rolling picture
Just moved my tv and dvd...think I've all the wires back in the coreect places. But when I turned the dvd player on the opening display is rolling horizontally and distorted
SOURCE: GPX d2816 problem
hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
Posted on Aug 21, 2007
SOURCE: Daewoo DVD player Dvg 8300se
I have same Modell....u need to change the PAL/NTSC on your TV set...as far as i know DVD output is only NTSC and can not be changed on Player itself.
Posted on Jun 25, 2008
SOURCE: DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Posted on Dec 17, 2008
  • 159 Answers
SOURCE: APEX Digital VCR&DVD PLAYER ADV-3800 will not play DVD's.
What it so far done, it looks pretty fine. I'd break apart the problem if is posible to do it, i mean maybe you have some other sets around the house or some friend who have them.
  • i'd test the dvd/vcr in a different tv
  • i'd test the tv with a different dvd
i would start over again the installation after this test.
the reason is to know if you can trust in those sets and second maybe with some other try the installation works
Posted on May 02, 2009
SOURCE: Distorted color on hdmi output
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
Posted on Jun 01, 2009
Proline LVD TV and DVD player problem. Hi, I can't get a picture using the RF option. I'm not sure what input I should select for this but I've tried them all and no joy in seeing the sky picture from the...
Hi Greg, i think your missing something simple.
Pick a channel number you want the Sky on, then in the tv set up
manually tune that channel to 68, or if it's showing lots of numbers for the frequency then just search towards the end and it should pick up. On the Sky box leave a menu showing so it's easier to spot when it gets to picking it up.
Nov 10, 2014 | Televison & Video
Tip
Proline DVD-1000 Region Free Fix
Proline DVD-1000 DVD Player Region Free Fix
Would you like to unlock your Proline DVD-1000 DVD Player to Region Free?
Follow these steps to unlock your Proline DVD-1000 DVD Player:
  1. Open the disc tray
  2. Place a region 1 disc in the tray, but don't close it
  3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time
  4. Press the Play button on either your remote or the player
Your Proline DVD-1000 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
Proline dvd player manual
Contact Proline (Comet group) web site for manuals.
Dec 14, 2010 | Televison & Video
Picture rolls
it come from TV itself because a difference synchronization IF YOU HAVE SUITABLE KNOB IN TV TRY TO MOVE IT A LITTLE IF NOT YOU NEED A TECHNICIAN TO SEE BOOTH A TV & DVD
May 29, 2009 | Cyberhome CH-DVD 300 DVD Player
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
Little white boxes rolling through picture
this is a problem with the mother board replace the mother board and then the problem will be solved
Mar 07, 2009 | Philips DVP642 DVD Player
Cyberhome 402 DVD "rolls"
I think I had switched to the PAL format by mistake. Fixed the problem by buying a new DVD player, was cheaper than the factory fix.
Jul 30, 2008 | Cyberhome CH-DVD 300 DVD Player
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Picture rolls horizontalic and verticalic
This may have to do with your TV instead of the DVD player. If you have a red, blue and green cable running from the Philips to your TV, check the back of the TV to see if it has a slot marked "H/V". If so, purchase a 7-part component cable instead of the usual 5-part - it will have a red/green/blue, red/white, and two h/v cables.
-Tha Mp3 Doctor
Dec 27, 2007 | Philips DVDR3320 DVD Recorder/VCR
APEX AD1201
buy an rf modulator and run it through that instead
Dec 30, 2006 | Apex Digital AD1201 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
