Question about Albatron LNX-21TIS-3 Television
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
    New Friend:
  • 4 Answers
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Posted on Jul 24, 2012
    New Friend:
Posted on Jul 21, 2011
SOURCE:
Turn on TV and picture and sound are great for about 60 seconds. Then the picture disappears but sound remains.
I would start with checking the power supply 12vdc output, make sure it is stable with no ripple. If the power supply checks out fine, I would then suspect the main board.
Sep 20, 2012 | Vizio VT470M 47-inch 1080p 120Hz 5ms LCD...
32" ALBA 15 MONTHS OLD.
I am afraid it sounds as though either your backlight or power inverter has gone faulty, may be worth contacting alba to see if they will honour the warrenty (unlikely but worth a go) otherwise maybe try your home insurance to see if its covered, failing either of these options, if you feel confident doing so, disassemble the tv and look for any signs of visible damage (capacitors leaking or any components looking burned or scorche, and replace. Try looking for any panel markings which will allow you to search for a price to replace the whole unit.
Unfortunately I cant give you and hard and fast cure, and it is very difficult to tell whether it is the inverter or the backlight has gone (having said that, if you are getting picture at the very beginning, it may suggest that the inverter is getting the power to the backlight ok, which may suggest its the backlight at fault.)
Hope this helps.
May 07, 2011 | Televison & Video
Alba lcd32880hdf tv after a few seconds the pitcher gose off
Ive got a albe Lcd32880HDF And the picture goes off 14 months old sound only?
Jan 07, 2011 | Televison & Video
LG 37LF66 TV - sound and picture for 5 seconds then it goes
power supply board may have bad capacitors look at them and see if the top of caps are raised if so they can be replace but i would get a new board if you do not know how to replace them
Feb 13, 2018 | Televison & Video
Its a un branded 20.9'' flat screen TV 3/4 years old. When switching on it may work for 1 hour or more or 3 minutes or not at all. Sound is OK just no picture although pressing controls on TV set sometimes...
most trouble like that shows a protect mode, there's a problem with the system and it shuts down,if the sound remain after the screen off, the back lights circuit is only in trouble.whole system shutdown.tell me
Aug 27, 2009 | Televison & Video
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
Losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Aug 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
482 people viewed this question
Top Albatron Televison & Video Experts
Ekse
Are you an Albatron Televison and Video Expert? Answer questions, earn points and help others
