Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Weed wacker FL-1500 wont start may have gal lines mixed up
I have a weed wacker FL-1500 and gas is not getting to the bowl
bulldogchief
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
SOURCE: Weed Eater Lightweight 1500 Leaf Blower Fuel Line
If you push the bulb and note the port the gas squirts out... this is the short line. The other port should **** up when the bulb is released... this connects to the long line with weighted filter in tank.
Posted on Nov 08, 2009
  • 3 Answers
SOURCE: fl 1500 gas line broken where does the two lines
new gas lines wont start
Posted on Dec 01, 2009
#1 Taper
  • 1041 Answers
SOURCE: new lines now wont start
Fuel Line Instillation: The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank,(about an inch). Make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, let me know.
Jim
  • 279 Answers
SOURCE: for the poulon-pro PP125 weed wacker, what is
3.2 oz 2-cycle oil to one gallon gasoline!
Posted on Jul 30, 2010
Smoke came out of the leaf blower while using it and it will not start again. What to do?
1 obtain new spark plug
2 completely empty the gas tank including the gas lines
3 Carefully remix proper amount of gas to oil ratio and try again.
Most Gas leaf blowers / weed eaters run on Gas mixed with Oil, if too much oil is present smoke will appear the spark plug will foul and it wont start. additionally nO oil at all in the gas will cause the engine to smoke seize .and never ever start again. so if you can still pull the starter rope try the above
:note: most small bottles of oil mix will do two gal
May 02, 2018 | Garden
What is the problem when my 27cc craftsman weed wacker starts but doesnt stay running
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 29, 2012 | Craftsman 27cc 2 Cycle Crank Straight...
Oil gas mix
50:1 50 parts petrol to 1 part oil
Jul 24, 2010 | Craftsman 25cc Gas Line Trimmer
Weed wacker wont start
Try a new spark plug or checka and see if it is getting fuel
Jul 18, 2010 | Troy Bilt Tb70ss Gas Trimmer
Weed wacker stall out
#1 fresh fuel mix #2 screen inside carb.
Aug 04, 2009 | Garden
2-cycle toro weed wacker does not start
Sounds like the flywheel has come loose and sheered off the key which locates it on the crankshaft without this the timing will be out ,
Jul 17, 2009 | Craftsman 25cc Gas Line Trimmer
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Apr 12, 2009 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
52 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
