Question about LG Heating & Cooling
Moisture is dripping from wall mounted unit - LG Heating & Cooling
    President:
  • 1,099 Answers
Find the drain hose outside the wall and attach a wet/dry shop vac and vacuum out the line......this clears blockages 95% of the time.
Unit needs to be slightly tilted to the out side. or drain plugged and dirty is the unit clean? to properly clean you have to pull take apart to clean.
Good luck, Hope this is helpful......
Posted on Jul 14, 2010
How do i deal with the dripping of water from my Mitsubiishi split system from inside unit? Will putting the unit on 19 and then turning it full bore clear over condensing?
NO
the water is condensation from the humidity in the air turning to water on the cold evaporator core
normally it drips into a tray and drains away outside
if it is inside ( running down the walls it indicates
the drain hole and tube is blocked or the evaporator core is covered in gunk and holding the water up and not dripping where it is designed to
Call an accredited ac specialist shop to clean the fins and drain tube
Jan 06, 2017 | Heating & Cooling
MLG LS307HV. Condensation is dripping off the bottom of the indoor unit. We've mounted the unit level but the left side continues to pull up. The wall mount is level but he unit is slightly out of...
the inside unit should be mounted with a slight tilt to the outside - so the water can drain outside.
also - be sure your drain hole (in the unit) is not plugged - either with dirt/debris.
Aug 04, 2011 | LG LS307HV Air Conditioner
My Samsung is mounted in the wall of my office. Once I turn the air conditioner off,it starts to leak water for several minutes. Any way to stop this? Frank
When the unit is on, go on the back side of the wall where the unit is
mounted. If this is a split system find the condensate hose and make sure it is not plugged and is draining.
If this is a window unit again go in the backside of the wall and see if it
is dripping there. If it is not, take the unit out of the wall, remove the top
and wash underneath the coils. Install the unit so it slants to the back.
Aug 04, 2010 | Samsung Heating & Cooling
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
Can I mount a window unit with no outside access
You could/can, but don't forget that (a) there is a good chance of heavy condesation, so size pan appropriately, or drain...and (b) The enclosed space where the drip pan is, is going to get quite warm. Hope this helps
Jul 13, 2009 | Frigidaire FAC124 wall/Window Air...
WATER DRIPPING INTO REFRIGERATOR AND FREEZING
Chances are, your doorseals are shot. This will allow excessive moisture into the unit.
Jun 25, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
I just bought a samsung 15k BTU window a/c, I haven't seen any water dripping out of the bottom of the unit. In fact there is absolutely no moisture anywhere. Is this normal. Humidity is low, and it is...
If the humidity is low then the amount of water removed will be low. The AC (I assume is a window unit) May be evaporating it off as soon as its drained outside..
Yes in low temps and humidity it is normal for no moisture to be made in abundance.
This is all assuming the temp is coming down as you direct it to.
Please rate me as high as you can and thank you for using fix ya.
Apr 28, 2009 | Kenmore 75050 Wall/Window Air Conditioner
Interior water leak on model ET18PKX6HB1 whirlpool refrigerator
The drain is clogged up. Check the clear plastic line that goes from the back to the drip pan on the bottom of the unit.
Mar 30, 2009 | Whirlpool Refrigerator Inverter Box -...
Heating & Cooling Logo
21 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
