Question about Frigidaire ATF6000ES Front Load Washer
I am getting the E20 error on my washer. I have
I am getting the E20 error on my washer. I have checked the hoses and neither are clogged or kinked. Do I need to replace the pump?
    President:
  • 1,382 Answers
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you !!
Posted on Jul 14, 2010
Error code E20
Hello igor_lyub - Typically error code E20 means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 12, 2013 | Frigidaire ATF6000ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Code E20
Oct 12, 2012 | Frigidaire Affinity ATF6000F Front Load...
What does E20 mean
The E20 error code indicates a problem with water drainage. Inspect the drainage hose for kinks that could impede the drainage flow. This frequently occurs when the machine is pushed up against the wall without allowing room for the hoses. If there are no kinks, the hose is probably clogged. Carefully detach the hose from the machine, and use a garden hose to force water through it. If the water doesn't pass through, use a plumber's snake to clear the clog. If there is no clog, inspect the drain pump for clogs. Unplug the machine, and open the small rectangular door towards the bottom of the front of the machine. Drain the pump through the emptying hose into a container until the water flow stops, and rotate the pump impeller to clear any foreign objects. Close the pump and restart the cycle. If the problem persists, contact a service center.
May 18, 2012 | Zanussi ZWF1430W Front Load Washer
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
I have Kenmore front load washer(don't have the model # yet)...during the normal wash cycle..at the end of it it does not spin, the diplay show E20. What seems like the problem??
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
E10 & E20 problem
e10 problems refer to water supply..so check the tap is on, the inlet hose is not kinkrd, and the filter in the inlet hose is not blocked.  e20 refers towater drainage,  so check the drain hose isn't kinked and the drain pump isn't clogged
Aug 09, 2009 | Electrolux EW1000i Front Load Washer
Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
May 31, 2009 | Frigidaire ATF6000ES Front Load Washer
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Jun 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
116 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
