Question about RCA HD52W59 HDTV Projection Television
Screen fades out
Screen comes on for about 15-30 minutes then fades out,it may come back on after about 10 mins......sometime, sound still works
  • RCA Master
  • 8,617 Answers
Thats a common symptom often caused by the Small signal board. You can get replacements at www.tvrepairworld.com They will also asist in obtaining the correct board for your model as there are several versions which arent interchangeable with each other.
Posted on Jul 15, 2010
19 flat screen vizio tv with know sound
There should be some loose solder terminals at its audio output stage circuit, or have a fault with its speaker.
May 22, 2013 | Televison & Video
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
When I start my computer, the monitor can take up to a 1/2 hr to display. I have dual monitors; the 'Acer' will eventually blink/show 'Acer', then fade. It repeats every 3 seconds. The...
your problem sounds like you have bad capacitors on your monitors power board. once you start it, they do not have enough capacitance to give to start the monitor, but after letting it for some 10ish minutes or so, they capacitate enough to start. even then, after some time, they will lose the capacitance because they are feeding the monitor in constant power when the power from the outlet drops a bit, but being bad - they will shut off your monitor. some repair shops can change capacitors only, others would make you change the all power board
Aug 04, 2017 | Acer AL1511 15" LCD Monitor
Volume fades out then may come back on-Proscan TV Model#PS35690LW
hello,
this will require you opening the back cover of the television.
Check for dry soldering and re solder in the audio section of the printed circuit board....
Good luck...
May 24, 2010 | Televison & Video
After my tv has been on for about 10 minutes, the picture and sound will go for a minute, come back on for another 5 minutes and then the picture will fade out but i can still hear the sound?
Ur LCD inverter board is dead.This board help the LCD screen to have a backlight to give u picture.Replaced the LCD inverter board will get ur picture back.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape,it pretty easy to replaced.
Apr 14, 2010 | Televison & Video
After watching for about 10 min the screen loses color and fades to black..there is still sound..sometimes it comes back on
That can be one of two items. First would be the small signal board as that has a history with the ITC222 series. The other board could be the deflection board haveing a vertical deflection issue which is shutting down the CRTs and allowing audio to run.
Mar 29, 2010 | RCA D61W20 61" Rear Projection Television
Bizzare problem with the color
Sounds like something may be wrong with your cable line might need to have it checked.
Aug 19, 2009 | Sony KV-32FS13 TV
Bmw radio in '95 325 works 5 to 10 min.,then fades out completly
just a thought is the radio a kenwood if it is ther is yor problam . bmw dashes get verry hot and kenwoods dont like the heat i have had this problem more than once
Apr 22, 2009 | 1995 BMW 3 Series
No picture,but sound ok
check your ribbon connections coming from power supply board there is 2 of them it will be the second one,theses ribbions connect to signal board.Sometimes causing set not to come on.
May 11, 2008 | RCA D52W19 52" Rear Projection Television
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
RCA HD52W59 HDTV Projection Television Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
