I need to increase the water temperature in my Rinnai Infinity 26 water heater. What numbers do I move on the switch board (SW1)
SOURCE: How do I relight the
It's fixed.
Posted on Aug 22, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Max temperature for Rinnai 556WT restricted to 74 degrees
There is no way to restrict the setting and keep it UL approved. If you cannot get the heater above a certain setting you have either too small of a heater, too much outside air entering the apartment or the gas pressures are not great enough.
Posted on Feb 20, 2009
SOURCE: Temperature adjustment for Rinnai infinity 20 hot water heater
You'll find all the information you need at http://www.rinnaiuk.com/download.htm
PDF's include schematics for all dip switches
Please note: you'll need to get the pdf that corresponds with the correct model you have.
Posted on Apr 13, 2009
gary1121
  • 332 Answers
SOURCE: I need the manual for a Rinnai Infinity 26 hot water system
you can get it off the rinnai web site they have a spot on there to get the internet manuel,, but from what you are saying you may need to adjust the thermostat, or the temp, remember even though you will have endless hot water it still takes the smae amount of timed for the hot water to get to your faucet,, not only that make sure your shower heads aren't holding back to much water pressure, if you don't have enough water going thru the unit it will not stay lit, if will come on and go off, judt to dstisfy the unit,, make sure the filter is clear, on the cold side there is a cap screw if you take it off there is a screen in side you just pull it out and clean it and reinstal it,,
Posted on Jun 27, 2009
  • 2069 Answers
SOURCE: rinnai infinity 26, water temp
Does it indicate any fault codes on the unit? otherwise, use this service manual here. it may be of some help.
Regards
Posted on Oct 30, 2010
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
How to fix gas heater Rinnai RCE-229H?
get a gas fitter in to fix the problem as gas is less forgiving than electricity
Jul 19, 2015 | Rinnai Heating & Cooling
Rinnai tankless water heater
the tempreature can be changed by changing dip stick numbers inside unit, If your unit is pre set @ 50 & installed before 2002 than you may have to change the mother board. If its preset 50 & after this date you can raise 3 - 4 degrees. If your unit is pre set 60 than you can go up & down. Manual is located inside cover, First check which unit you have, Before you do change anything take a picture first, so you can reverse what you have done if need to. ALWAYS TURN POWER TO UNIT OFF BEFORE REMOVING COVER.
Jan 11, 2014 | Rinnai Water Heaters
I need a service manual for a Rinnai Infinity 26 continuous flow hotwater system - REU-VR2626WG-AK Can you help me? Linda
I left Rinnai only about a year ago at a levle of State Service Manager. I had been asking for service manual for for many, many months. Basically as far as I am aware there is not a service manual for the WG. If you google Rinnai Infinity 26 manual you can get a PDF from the Rinnai NZ sales site but his dates baack to 2003. Unfortunately there are major changes to some of the components but it might be better than nothing. Just don't use part numbers, and you might find bits to check that now have voltage and resistance differences. Send a message to Rinnai complaining, I encouraged people to do so even when I worked for them!
Aug 26, 2010 | Water Heaters
How to operate Rinnai V1500 water heater?
The V1500 is in essence the same as Infinity 26. Rinnai have manuals on their website.
Here's a link
http://www.rinnai.com.au/images/stories/operating_instructions/Hot_Water/All_Continuous_Flow.pdf
If you have any specific problems or queries just post them on this site. I check it every few days.
Cheers
Aug 15, 2010 | Water Heaters
Hi, our plumber has hooked up a new infinity xr-26 but the existing remotes don't work. He says it's a simple 2 wire connection but ther's no cirrcuit
Check with Rinnai to see if the old remotes are compatible with the new heater. Might mean upgrading the remotes too but the wires should be OK. Double check that he has actually connected the wires to the heater. Rinnai in Australia recentyl changed the connection point for the wiring. I can help further with this if this is the issue (not sure where you are!)
Mar 07, 2010 | Rinnai Digital Remote Water Heater Control...
Can't get hot water heater to work - Rinnai Infinity 18
If you can get to the gas valve make sure it is in the on position and not in pilot or off. Does it sound like
a spark ignition system? Even though you say the gas valve is on, by code thered should be a gas shutoff valve located within site of the unit. Follow the
gas pipe until you find such a valve and make sure its on
Feb 07, 2010 | Rinnai Vent Free Gas Heater/
Jun 25, 2009 | Rinnai Digital Remote Water Heater Control...
Temperature adjustment for Rinnai infinity 20 hot water heater (with out using remote controllers). Dip SW1 is used for temp control via configuration of 6 dip switches.
Feb 28, 2009 | Water Heaters
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
