Question about Intex Pool & Spa
I LOST MY OWNER MANUAL FOR MY 18X48 EASY SET INTEX POOL AND I DON'T REMEMBER HOW TO SET UP THE PUMP AND FILTER
Attach the hose from the lower part (the pump) to the lower hole (intake) on your pool. The attach the hose from the taller part (the filter part) to the taller hole on your pool.
Open the spigot on both parts of the pool (turn, lift and lock into open position) openings. You'll hear water fill up the filter section. Make sure the knob on top of the filter section is a little open and let the air bleed out. You'll know when it is full of water when it starts spitting water out. Close the top then.
Plug in your pump and turn it on. If it doesn't take much water in at first, reopen up the knob on top of the filter to let more air out. Once it spits water, close that up.
Hope this helps!
Posted on Jul 16, 2010
I have an Intex easy set pool, with inflatable ring 18x48 will the 14 inch sand filter work with this pool?
25,900 gallons if 4 feet deep see pool school for info your pump takes about 8 hours to turn over water that filter and pump undersized for pool if using it with bathers will not keep up and be a green mess step up filter and pump size you will have less hassle and use less chemicals and the children and you will be happier
Jun 18, 2018 | Intex Pool & Spa
What would be the best automatic pool cleaner for intex 18 x 48 easy set
the vacuum you are using is probably the best for the system you have. if you want a REAL pool vacuum, get a REAL pool. there is a reason that these are considered disposable pools. dont get me wrong, any way to cool off is great and these pools allow people this 'luxury' at a reasonable cost but they are assembled with low end, non standardized equipment that doesnt match with traditional pool equipment.
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
How much salt to put in 18x48 pool frist time
Frame Set or Easy Set?
If Frame Set = About 6,400 Gallons
If Easy Set = About 5,450 Gallons
Salt levels in a pool for a generator to operate efficiently...
2700 ppm Minimum to 3400 ppm Maximum, 3200 being Ideal.
So...
In pool water with NO Salt reading at all - 0, then you will add 2.67 lbs. of "Pool Salt" (which is almost Food Grade Quality! - NOT Softener Salt!) per 100 gallons of capacity.
This chart has lots of useful info: take a look
https://www.hayward-pool.com/pdf/manuals/Salt&SwimChemistryGuide.pdf
Jun 19, 2014 | Intex 18' x 48" Easy Set Pool Package
Have a intex 18x48 above ground pool, how much salt to add to it for the first time
If you have an Easy Set pool, should be around 5500 gallons, then the initial salt add should be approximately 135lbs...
If you have an Circular Metal Frame pool, should be around 6400 gallons, then the initial salt add should be approximately 160lbs...
Make sure you only run the pump for 24 hrs to properly dissolve the salt, then you can set your chlorinator to desired time... Start high and work your way down... 10 hrs pump and 8 hrs chlorinate...
Check your chlorine level after the first two days and see if it starts to climb above 3ppm, if it does, lower your cycle time until you can maintain the 3ppm level...Hope this helps you?
Good luck and enjoy your pool!!!
Aug 25, 2011 | Intex Automatic Salt Water System for ...
Is this pump large enough for a 18X48 easy set pool? I have been unable to get this pool clear dispite my best efforts with chemicals and taking samples to be tested. I really feel it's not a...
THE PUMP IS LARGE ENOUGH. i HAVE THE SAME . ALL U NEED IS TO BRASH YOUR POOL ONCE A WEEK WITH THE PUMP RUNNING SO THE PUMP SUCKS ALL THE ALGAE AND THE RUBBISH FROM SCRUBBING.
Aug 06, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Intex spare parts
intexstore.com ,not very much
Jun 22, 2010 | Intex Easy Set Pool 15x36
How much salt to I add to an intex saltwater pool that is 18x48?
all depends on what kind of intex 18x48 straight wall blow up ring and so on
Here is a link to the manuals look up pumps I think it is the top choice even if it is not your filter open it and go to pg 17 and look up your pool it is 135 to 160 pounds depending on your pool
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 19, 2010 | Intex Automatic Salt Water System for ...
Intex Easy Set 530 Gallon swimming pool filter pump is leaking. How do we get it to stop?
You will need to go to the manufacturing web site and get a new seal for the pump.They cost some where around $1.00 to $2.00.
Jul 02, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
Intex filter model 633 with no instruction manual on how to set i
You can go to the website for Intex products and once you get to product section you can find and download a pdf manual
Jun 14, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Pool & Spa Logo
471 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
