Question about Panasonic Microwave Ovens
My panasonic genius sensor 1250w with inverter is showing H98 on the display window what can I do to get it to work
3 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
This is most likely because of a faulty interlock monitor switch, operated by the door latch. If it thinks you're running the oven with the door open it will cause the fuse to blow (or trip a circuit breaker in your case). The switch may be bad (not opening as it should when the door is closed) or out of adjustment.
The switch is replaceable and it's not a costly part. You should have microwave service done by a professional, especially if it involves the door. There are potentially lethal voltages present with the cover off, and the possibility of microwave leakage is the repairs aren't dome properly.
Hope this gets you cooking again. Thanks for using Fixya!
Posted on Feb 17, 2010
SOURCE: panasonic inverter genius sensor 1250w, turns on
try locating the primary door sensor. this is probably burned. replace the door sensor with appropriate amp rating - usually 16A (or higher) 123vac
Posted on Mar 01, 2011
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Jan 25, 2014 | Microwave Ovens
Code H98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
You can order Panasonic parts & accessories from Encompass here or you can call them toll-free at 866-779-5835.
Nov 30, 2013 | Panasonic Genius Prestige Inverter...
Panasonic inverter 900w microwave fault code h97
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Panasonic Inverter Genius Sensor 1250W reads code H97
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Nov 02, 2012 | Microwave Ovens
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 26, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Panasonic inverter genius sensor 1250w, turns on for about 3 sec. then goes off, no codes.
Feb 09, 2010 | Panasonic Microwave Ovens
Panasonic Model NNS768BA Genius Premier 1100W Display works - nothing else comes up H98
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 14, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
1,033 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
