Question about Nakajima AE-710 Typewriter
Do you sell a replacement roller handle for AE710? The knob at the left side of the roller? I can only turn the roller by hand as the knob is broken.
  • Nakajima Master
  • 3,594 Answers
We have them in stock 15.oo includes shipping.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Jul 14, 2010
Brushes not moving
The DC14 has a "brush control system" operated by a knob on the right side of the base. This knob has two positions: "bare floors" (or "off") and "carpet" (or "auto"). The motor turns the roller only when the knob is on "carpet", and even then only when the handle is tilted back (with the base still flat on the floor). Make sure the knob is in the correct position.
Next possibility is that a belt has broken. The problem is that this system uses two belts, only one of which is easy to see. If you're sure that the control knob is in the correct position, and still the roller doesn't turn (although you can turn it freely by hand), then most likely a belt is broken. It's also possible that the clutch itself has failed.
Belt replacement on this model is not for the faint-hearted! To see what's involved, you can go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC07 clutch replacement" (DC14 is similar). Then you have to decide who is to do the job!
I value your feedback, so please remember to rate this response. Good luck!
Jan 24, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 roller doesn't turn but everything else works. The belt is on correctly, the roller is clean and it turns manually so I can't figure out the problem.
The DC14 has a "brush control system" operated by a knob on the right side of the base. This knob has two positions: "bare floors" and "carpet". The roller will turn only when the knob is on "carpet", and even then only when the handle is tilted back (with the base still flat on the floor). The problem is that this system uses two belts, only one of which is easy to see. If you're sure that the control knob is in the correct position, and still the roller doesn't turn, then most likely the belt that you can't see is broken (that belt goes from the motor to the clutch mechanism behind the control knob).
Belt replacement on this model is not for the faint-hearted! To get an idea of what's involved, you can go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC07 clutch replacement". It's a slightly different model, but the principle is the same. At least you will see how to remove the clutch cover so you can check on the other belt and confirm if this is the problem or not.
Jan 18, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Do you sell a replacement roller handle for AE710 Nakajima Typewriter
We have them in stock they are 7.50 plus shipping.
DickyO
216-241-0027
Dec 14, 2009 | Nakajima AE-710 Typewriter
Dyson brush roller will not turn
Hi.
Your Dc14 will have A clutch unit.
Check that when you pull back handle to vacuum that the clutch control knob which is located front lower left side of machine moves to drive position & is not stuck in off or park position.
Rotate it to drive if its at off or park when you have lowered handle.
If adter checking this you still have no brush rotation you will need to remove clutch unit to either replace thr belts or fit new clutch.
Try this site for further help http://dysonmanuals.llc.nu/
Dec 29, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt not turning
Hi.
Oct 27, 2008 | Dyson DC14 All floors Bagless Upright...
Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
Jun 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt
Hi.
Your Dyson will probably have A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left front side of machine looking from the front & rotates to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/index.htm
May 26, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Roller not moving when on
Hi.
Your Dyson will have A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front rotates to drive position when handle is pulled back.
May 23, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc04 absolute
Hi Diana.
Your Dyson has A clutch this has 2 belts, One goes clutch to motor the second goes clutch to brush roller.
You have either A snapped motor to clutch belt or the clutch control knob is not rotating to drive position when you pull the handle back to clean carpets.
Firstly check the control knob this is situated on the front lower left hand side of machine.
EG if your machine is silver & yellow the knob will be yellow approx 2" or 5cm in diameter as I said ensure it moves from off or park to drive if it doesnt move rotate it by hand when you have lowered the handle to vac carpet.
If still no brush roller drive you will need to strip machine down to remove the clutch & gain acces to the belts.
Its A lot of work to explain so try this site http://dysonmanuals.llc.nu/ for clutch removing manual can send via email very quickly.
May 20, 2008 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Brush roller won't turn
On my Dyson, there is a brush reset button on the top right hand side (if you are looking at the front) that you can press to reset the brush. I was vacuuming and too lazy to move a toy and this worked for me once I freed the rope from the brush.
May 18, 2008 | Dyson DC07 All Floors Bagless Upright...
Nakajima AE-710 Typewriter Logo
235 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
