Question about Cannon Woburn 10560G / 10562G / 10565G Gas Range
I have a cannon lincoln gas cooker and the ignition wont work
4 Suggested Answers
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
Posted on Jan 31, 2009
  • 11 Answers
SOURCE: Gas cooker, the oven works but no gas going to rings
you need to check the pipe that take gas in to rings , and check the adjuster button .... where you live may be i can help you
Posted on Jan 25, 2010
SOURCE: i have a cannon lincoln model 10255G ignition has
Hello
Replace battery.
It's similar to a watch battery found at the base of the cooker front.
You will need a flathead screwdriver to open casing.
Good luck.
Posted on May 14, 2010
My cannon duo cooker was working one day then next day the clock doesn't work, the ignition wont work theres no gas coming through to lite oven manually whats the problem the rings work perfectly
Gas ovens invariably have a safety thermocouple to cut the gas off automatically if the flame goes out, due to an interruption in the supply for instance. The thermocouple must be temporarily over-ridden for the purpose of lighting the burner and pilot and often the override is mechanical but considering the clock and ignition has stopped working it would be reasonable to assume your oven has an electrical or electronic thermocouple override.
It would seem either the mains supply to your cooker has failed or the internal power supply has a problem. With such a sophisticated oven, even if you had been able to light it manually, it is possible the temperature control wouldn't have worked.
Mar 26, 2016 | Cannon Kitchen Ranges
How do i change the ignition battery my gas cooker
Our battery compartment is right down at the bottom of the cooker so I have to lay down and use a torch to see and a small Allen key to release the battery cover...
Nov 02, 2015 | Cannon 10476G Dual Fuel (Electric and Gas)...
The clock has stoped working on my cannon chesterfield cooker, why!!
i have the same cooker (in brown colour) and is just 3 years old. The clock was coloured green and over the last 6 months or so has gradually faded to no illumination at all. Then it started to buzz very lightly when the mains was switched on to ignite the gas. In August 2011 phoned Cannon Indesit repair line on 08448 224 224 and agreed to pay £104.99 for call out and labour to fix. The parts are covered for 5 years so no charge for the clock. Engineer took 22 minutes to replace the clock which is now a deep yellow colour and much easier to see in the daytime.
Sep 03, 2011 | Cannon Chesterfield C60G Kitchen Range
How to reset the clock on my cannon chesterfield gas cooker
Chesterfield gas cooker/clock - doesn't display time, ticking sound in background, timer still works but difficult to set more than 15-20 minutes.
Oct 17, 2010 | Cannon Chesterfield C60G Kitchen Range
I have a cannon lincoln model 10255G ignition has stopped working how do i fix thanks
Hello
Replace battery.
Good luck.
Apr 02, 2010 | Cannon Kitchen Ranges
Bottom oven on Cooker Cannon c60gcw will not ignite, continuouos sparking and no gas when knob turned on
Fault caused by trapped and therefore cut wiring to main oven valve at bottom rear of cooker causing wiring overheat melting and open circuiting electrical supply.
Sep 15, 2009 | Ovens
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
The clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Dec 05, 2007 | Ovens
Cannon Woburn 10560G / 10562G / 10565G Gas Range Logo
549 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
