I have a telefunken tne 1300b amp/tuner/cd player stero and when i turn on it just says wait on the lcd screen and wont change and nothing works can you help :)
SOURCE: error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Posted on Dec 27, 2007
  • 10 Answers
SOURCE: lanzar model SD43MU(( dvd/cd player wont work not funtions for that wont even appear?
I have a similar Lanzar unit. I had it in twice while it was under warentee for the same issue. I also had it in a couple more times for other issues. It cost me about $30 shipping both ways each time I returened it. About a month after the warentee expired, the DVD quit ejecting again.
Bottom line, I would look at purchasing a different uint or use an ipod instead of the CD.
Posted on Apr 21, 2008
SOURCE: Memorex Model MD6451R CD play - LCD readout "hold"
Looking down on the unit from above with "Memorex" reading left to right look at about one oclock. There is a switch marked hold ...turn it off. Its black on black, so its hard to see. It disables the onboard controls. The remote if you have it works either way, but when on hold it will act just as you describe.
Posted on Nov 08, 2008
  • 323 Answers
SOURCE: CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Posted on Feb 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 19, 2009
I have no sound with the ipod or dvd but the fm stero works. I took this out of my old truck and it all worked in there but once i installed it in my new car there is no sound when playing dvd/cd or when...
it sounds like you are going through an external amp. try using the blue/white wire instead of the blue wire. the blue wire is antenna remote turn on. the blue/white is amplifier remote turn on. the blue wire turns off when leaving tuner mode.
Feb 02, 2011 | Kenwood KVT-514 Car DVD Player
My alpine cda9885 plays my subs when the tuner setting is on but nothing else, The amp turns off when I switch between the settings and doesn't turn on until on the tuner.
sounds like you have the antenna remote wire (blue) instead of the amp remote wire (blue/white stripe) turning the amp on. the antenna remote turns off when the radio is switched to cd mode.
Sep 08, 2010 | Alpine CDA-9885 CD Player
My Emerson stereo MS9903TTC won't turn on. It was working fine last night and this morning when I push the power button nothing happens. I tried selecting different modes, (cd, tape, phono, tuner) but no...
I had the same problem the power button is pushed in. You did not mention if your unit came with a remote control if it did use that to turn your stero on and off. you will not be albe to use any of the buttons on the stereo if the controls are listed on the remote IE; Cd player, radio tape or tuner. try this please. hope this helps
Feb 10, 2010 | Emerson Audio Players & Recorders
AKAI CD-M600 CD PLAYER not working.
Akai CD player playing very S L O W L Y and the CD door won't open and if it does, it goes into ewject mode. Help!!! Has an internal motor died??? Can i be repaired???
Mar 29, 2009 | Audio Players & Recorders
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Stero installation
need wiring harness clip and install kit. It is pretty easy after that if you aren't installing amp or subs. what is your question, how to get factory radio out?
Aug 31, 2008 | Pioneer DEH-1600 CD Player
Lanzar model SD43MU(( dvd/cd player wont work not funtions for that wont even appear?
Mar 01, 2008 | Lanzar SVD26MUT Car DVD Player
No sound
The only fuse on you stero is for power it's a 6.3 amp 125 volt it'on the main board. I have the sam problem I found a resistor on the board that controls the power amps on the heat sink. A lab here charges 35 dollar bench charge and if you want them to fix it they will apply it to the job. I own the same model and i went to circuit city they had lot of different system on sell. So before i put that in to an old system i'll buy another one
Jan 19, 2007 | Pioneer VSX-403 Receiver
138 people viewed this question
k24674
Marvin
Marvin
