Question about Black & Decker B2300 Bread Machine
Can not get the bottom off have removed the screws
Http://ianchristie.info/?page_id=58
Posted on Feb 09, 2013
How do I remove the back cover of Vizio?
Hello, first you must remove the center section of the back cover. there are 2 screws at the bottom of it, and a large screw in the center a couple of inches from the bottom. When those screws are removed, slide the center section down ward towards the bottom. All of the main components (power supply and main board) are exposed. There is a screw in the center bottom that will need to be removed as well . If you have all the other screws removed, the back cover should be ready to remove.
Sep 03, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
Remove the cover on an emachine e525
Umm, well there are things like the motherboard and plamrest that have screws in them that might be holding it. You just can't remove the bottom cover, You have to start by Removing the bottom screws like you did, but then you have to remove other things before you can get the bottom case off. Also the VGA Port might have screws on both sides of it that keeps the bottom case from coming off.
Below are some steps to follow.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
May 31, 2012 | Computers & Internet
Take apart a hp gv7
Get some cups and label them for all the screws you take out. Have a digital camera to take photos. Start with the bottom of the laptop by removing all the screws and then the components that are there such as the Hard drive, DvD Drive, etc. Pay close attention to screw that hold the keyboard, they will have the icon of the keyboard next to it. They might be located inside the battery compartment or on the bottom of the motherboard. Some models may not have keyboard screws on the bottom.
After all the bottom screws are removed, turn the laptop over and remove the strip that is above the keyboard. Be careful because there might be a cable under it that has to be removed.
Then remove the keyboard, there might be screws holding it down and catches on the site that hold it down. There will definitely be a cable under the keyboard so remove it carefully.
Next you start removing the LCD Screen, then the palmrest. Once the palmrest is removed you will start removing the motherboard from the bottom case.
Good Luck
Apr 23, 2012 | Computers & Internet
How to install fan #1
Hello
Put on the work gloves. Turn the Samsung rear-projection television around so that the back is facing you. Use the Phillips screwdriver to remove the screws from the bottom left, the bottom right and across the bottom of the TV. Remove the screws that are directly above the ones on the bottom left, the bottom right and the bottom of the TV. Put the screws aside
Insert the flat-edged screwdriver into the seam between the bottom plate and the back of the TV. Wiggle the flat-edged screwdriver into the seam to loosen the bottom plate. Remove the bottom plate and put it aside.
Locate the fan assembly inside of the TV at the left corner. Use the Phillips screwdriver to remove the screws from around the fan assembly. Put the screws aside.
Mar 14, 2011 | Samsung LN40A630 40 in. LCD TV
How do I change a seal beam headlight in a for f250 2001 year? I find the 2 screws on top but can't find a screw on the bottom.
To change the sealed beam headlight bulb you will have to start by removing the parking lamp assembly. There should be 2 screws on the bottom. Remove these and unplug the electrical connectors. Next you will need to remove the headlamp bezel. There will be 4 screws(2 on the top and 2 on the bottom). Next you will have to remove the headlamp retaining ring. Once again there are 4 screws(2 on the top and 2 on the bottom). Disconnect the electrical connector and remove the bulb. To reinstall reverse the removal procedure.
Mar 08, 2011 | 2008 Ford F 250 Super Duty 4WD
How to replace latch
The latch is incorporated into the palm rest which you can buy on Ebay for around 25 bucks.
The simplist way to do this is to remove all the bottom case panels to make sure there are no hidden screw holes. Remove the connectors on the wireless card, remove the battery and the three black screws inside the battery compartment. Remove the screw and the dvd drive. Remove all the screws from the bottom case. Turn the laptop back over and remove the power button cover, start prying the cover up on the right side, it will come off as long as you removed the three screws from the battery compartment. Once the cover is off, press on the small indentions around the edge of the keyboard, this will release the keyboard. Release the keyboard cable clipand remove the keyboard. Unplug all the cables from the motherboard and unplug all the flat cables from the palmrest to the motherboard. There are several screws holding the palmrest to the bottom case assembly. Remove these screws and note their location. Once the screws have been removed, start working the palmrest free from the bottom case half, if all screws have been removed will pop apart, lift it from the back and tilt it toward the front and lift the palmrest away.
Mar 30, 2010 | Acer Aspire 5315 Notebook
How do I remove the radio from a 1998 Honda CR-V?
UNSNAP PUSH-PIN FASTENERS FROM BOTTOM OF CENTER CONSOLE
AND REMOVE BOTTOM PANEL.
2. EXTRACT 4 SCREWS FROM BOTTOM EDGE OF BEZEL. EXTRACT 4
SCREWS FORM INSIDE DASH BELOW POCKET. PULL CUP HOLDER/
POCKET ASSEMBLY OUT OF DASH AND REMOVE.
3. OPEN GLOVE BOX AND REMOVE STOPPERS. EXTRACT 2 SCREWS
FROM RIGHT SIDE OF CENTER DASH BEZEL..
4. FROM BELOW STEERING WHEEL EXTRACT 2 SCREWS FROM BOTTOM
EDGE OR PANEL, UNSNAP UPPER EDGE OF PANEL, UNPLUG, AND
REMOVE.
5. UNSNAP TOP EDGE OR CENTER LOWER BEZEL, UNPLUG, AND REMOVE.
6. EXTRACT 2 SCREWS FROM SIDES OF POCKET.
7. UNSNAP RADIO/AC CONTROL DASH BEZEL, UNPLUG, AND REMOVE.
8. EXTRACT 2 SCREWS FROM EACH SIDE OF THE RADIO BRACKET
ASSEMBLY TO REMOVE RADIO FROM DASH/AC BEZEL.
Apr 09, 2009 | 1998 Honda CR-V
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
I NEED TO REMOVE THE DOORS
Removing doors can be tricky... if you need to reinstall them.
First remove the plastic cover top door if it's an over under. Usually the screws are 5/16 there are 3 screws usually. Remove 2 screws loosen up the third. swing the bracket out of the way. Reinstall the screws you removed, this keeps interior screw plate in place and does not allow it to shift. Remove the 3rd screw , Remove the bracket reinstall the 3rd screw.
lift up and remove the door rememder washer locations.
Is there a washer on top of the middle bracket? Do not loose this or get it confussed with the bottom washer on the bottom bracket. Next there should be 2 screws on the middle braclet.
Remove one, loosen the other swing the bracket around. Install the removed screw. Remove the second screw. Remove the bracket, reinstall the screw. Lift bottom door up remove.
Now do the same to the bottom bracket. Or do not remove the bottom bracket if you don't have to. hope thisd helps.
Jun 01, 2008 | KitchenAid Refrigerators
Black & Decker B2300 Bread Machine Logo
80 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
