Question about Dell Inspiron 1525 Notebook
After a year used, when switch on the power button of laptop, it is just blinking the leds on key pad and going to swith off and again switch on and switching off. And even am not getting the display.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
The computer is not booting, you need to get your computer to a system engineer to check on the motherboard. good luck
Posted on Jul 14, 2010
Hello guys. I need help with my hp dv4 1225dx pavilion. It all started with not powering with battery power. But the battery is in perfect condition. When I plug in the power cord. It comes on and I...
It sounds like a hardware issue, if you're getting the LED's blinking when pressing power, there IS power to your mainboard (which is a good thing). Some manufacturers have placed LED blink codes within the system to let you know what's going on, but I have a feeling it's either A) your battery or B) your hardware, such as a bad RAM stick.
Try removing the battery and with the power plug connected switch the laptop on. If it works, you've got a bad battery.
Try removing a single RAM stick or replacing both.
You could search HP Pavilion LED blink codes to further address the issue.
Jul 18, 2012 | Computers & Internet
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
How do I change the Waste Ink collector on a Pixma MP170?
Cleaning or changing the pad is a messy project. This ink pad reset will reset the printer ink use conter to new status and your pad full message will be gone. This is a common occurance with Canon printers and the fix causes no harm. I reset my own MP470 about two years ago without incident.
This reset has been sucessful on many MP150 and simular units and should work on your MP170.
The second works on models with different control pads simular to theMP470.
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Mar 27, 2011 | Canon Office Equipment & Supplies
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Good morning, how do I reset my Linksys SD2005 5-port Gigabit Ethernet Swith to default factory settings.
There is a tiny reset button on the back of the switch.
Power off the switch. keep the tiny black switch pressed and do not release that. Power On the switch and the sys LED will blink slowly and then rapidly. Now release the black button and wait for 5 minutes.
Oct 28, 2010 | Linksys SD2005 5-Port Gigabit Ethernet...
I use URC-3021 w/ Magnavox TV. I bought a
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
  1. Turn on your DVD.
  2. On the remote, press the CBL key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
Number keys on think pad lock using openoffice.org
On Thinkpads laptops the keys on the right hand side double up as the number keypad. To switch on the Number lock key pad on - press and hold the Shift key and press the NumLk/ScrLk key, it is above the F11 key, the Num lock LED will also light up. Press these keys again to turn off the Numer Lock.
Nov 10, 2009 | IBM ThinkPad T42 Notebook
Shutdown & error led blinking 2 times
Shut off your projector by swith on the back near the AV inputs, leave it off for about five minutes. Then switch it back on, manually press the power button, let it start for about 5-10 seconds then continue to hold power button until picture appears. It worked for me, good luck to all.
Mar 24, 2009 | NEC HT1100 Multimedia Projector
Switch with 8 leds blinking (and not working)
You probably have to buy another switch. However, before you try that - the eighth most right cable - switch that out to see if it was a cable problem. That's an easy thing to try before you buy another switch.
Mar 17, 2009 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Dell Inspiron 1525 Notebook Logo
70 people viewed this question
Alun Cox
