Question about Garden
I have a Husky 1750 electric power washer that needs a gun. The hose is good. The part number used to be IPPR83848. Where can I go to find this part? I have checked everywhere. Thanks Jim
  • 4 Answers
SOURCE: No soap dispensing in power washer
ball and spring stuck on end in in filter
Posted on Mar 29, 2009
  • 26 Answers
SOURCE: Need parts diagram for Husky Pro Multi-purpose spray gun
Call tech support, theyll fax or email you one...
Posted on May 02, 2009
woobie dog
  • 1273 Answers
SOURCE: no pressure
It is probably air locked....Here's what you need to do. Connect the garden hose, and HP hose, but not the gun. Turn on the water, and let it run while you make sure that there are no high points in the garden hose that can trap air....Work the hose so that any air is displaced through the pressure washer. Continue in this manner through the HP hose. Shut off the water and connect the gun. Turn the hose back on, and operate the gun for several minutes, pulling the trigger and releasing. This alternately allows the water pressure to build up on house pressure and then to depressure, pulling residual air from the system. Release the trigger, and start the machine. Usually, this is enough to get full washing pressure. If it is very difficult to start, you can hold the trigger down on the gun and pull the start cord at the same time. Holding the trigger down acts as an unloader, making the starting easier.
Hope that this helps, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 31, 2009
  • 22 Answers
SOURCE: husky 1650 PSI power washer hose got brittle and broke.
If the $$ that you Husky Dealer is asking is to tall, try a garage that make brake hoses. Take the hose with you and many times they can remove your nozzle and install it on a new piece of hose. MAKE SURE that they understand that this hose is for a pressure washer...DO NOT use just any hose...it MUST be a high pressure rated hose.
Posted on Oct 07, 2009
bbreton
  • 437 Answers
SOURCE: Hi I need a Wiring Diagram for husky power washer 1750
I did some searching I found www.huskypowerwasher.com/manuals_specs.php.
Go there and look for your model.
Good Day.
Posted on Nov 07, 2009
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
Anybody know how to remove the wheels on a Husky 1750 power washer?
where does the link-mechanical gov. rod connect to the carburetor on the craftsman pressure washer number 919.762350.
Sep 28, 2013 | Dayton Wire Wheels Dayton Twin-Piston...
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Hi I need a Wiring Diagram for husky power washer 1750. I took the power switch out and I can't remember how the wires go back on. Thanks!
Good Day.
Nov 06, 2009 | Garden
Husky 1650 PSI power washer hose got brittle and broke.
Oct 07, 2009 | Garden
No pressure
Jul 31, 2009 | Garden
Problem with pressure washer line seems to be cracked the line that has the gun and puts the water out has a crack how do I get a new one?
Lowe's and Home Depot keep a supply of hoses. Take the old one with you, and match it up. Or, you can take your make and model number and order one on-line.
Regards, --W/D--
Jul 14, 2009 | Karcher 1750 psi Electric Pressure Washer
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
Mar 29, 2009 | Garden
Garden Logo
284 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
