Question about Vizio P2 42 in. HD-Ready Plasma Television
How to remove a stand on L42HDtv10a - Vizio P2 42 in. HD-Ready Plasma Television
Vizio L42HDTV10A won't come on
Power supply fault. You have to check the components in power supply or replace the power bord.if you wish to get some more details then check the link below.
www.electro-medical.blogspot.com
Jul 01, 2016 | Vizio Televison & Video
My Vizio TV model L42HDTV has been turning on of itself in the wee hours of the morning. Anyone know why?
Main board fault. Contact any service technician. Ask him/her to check the main system control section circuit to your TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 28, 2014 | Vizio Used Original L42HDTV10A Remote...
My vizio L42HDTV10A mfg date:november 2006 turns itself off about 5 secs after I turn it on. Is it fryed or can this be fixed?
it can be fixed the problem is in the power supply..but since the tv is old my advise is to buy a new one as it will cost you to get it repaired.if not then get a repairman to do the job.good luck.
Sep 23, 2011 | Vizio Televison & Video
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
Find
They Have to be bought from Vizio.
Mar 04, 2008 | Televison & Video
Vizio L42HDTV10A sound problems
In my case, turning the surround sound OFF is what fixed the problem. The bass contibutes most to the perception of the location of a sound. If surround is ON without surround speakers connected, the internal TV speakers can only take the place of what would be the front speakers in a surround system. So turn surround OFF and set your bass preference wherever you want it. That worked for me.
May 29, 2007 | Vizio L37 Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
90 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
