Question about Zanussi TLE1116W Top Load Washer
Manual booklet hi ive just bought a second hand top loader washing machince,im wondering if i can buy an instruction book for it the model is aquacycle 1100,tle 116w type 94p 226999 pros. n.913761461 ipx4 sernr 14700015. my name is pamela parsons 23 dening court, withycombe village road,exmouth ,devon ex8 3ar.i do hope you can help me.thank you pamela parsons.
SOURCE: Zanussi 1210 Front Loader
I have the same problem (kev82) can't see a red wire though on mine, Two gray wires though on mine connect to two wire connectors just above the motor. There are 3 connectors near each other. One for the 1st gray wire, the 2nd for a green/yellow wire and the 3rd for the other gray wire. They all seem to be connected to the side of the drum. Hope this helps
Posted on Oct 23, 2008
barkencoa
  • 3463 Answers
SOURCE: lost instructions
Go to ; www.serviceforce.co.uk
Then click on service center locator, and follow the instructions.
You should be able to find the information you require.
Please rate my fixya solution.
Thankyou.
Posted on Jan 31, 2009
SOURCE: haier hw-c1460tveme-u error 7 help??
HOW TO FIX ERROR 7 PROBLEM!
This problem is quite common on these machines, especially just after the machine has been moved. As a previous poster has said, Err 7 is a motor error. It is usually because the electrical connector has become detatched from the motor. Here is how to fix it.
  • First of all, PLEASE unplug the machine from the wall socket! And switch off the water supply too!
  • Pull the machine out from under the counter, and turn it so that you have access to the back of the machine.
  • Remove the 3 phillips screws that secure the back plate. You are only removing the small plate immediately behind the drum, not the whole back panel!
  • Look through the hole you have just created by removing the panel down towards the bottom of the machine. You will see the motor. Hopefully you will also see a 7 way connector not connected to anything, and a 7-way socket on the motor! (7 way means that it connects 7 different wires!)
  • Plug the connector back on to the motor. Don't worry, it will only go one way round, so you can't get it wrong. If the connector looks like it is connected, give it a little wiggle and a push to make sure it is fully home.
  • Replace the the small back panel, taking note that the top of the panel goes BEHIND the main back panel, and the bottom of it goes IN FRONT of the main panel. (This could be the other way round, I can't remember!)
  • Push the machine back under the counter, making sure that it is level (level it up by turning the 2 feet at the front of the machine until it doesn't wobble), reconnect the water and plug it in to the electricity supply.
  • Turn the machine on and attempt to operate the machine. (Top Tip: Select the wool or quick wash to test the machine, otherwise you will have to wait 3.5 hrs for the machine to go through a cotton/linen wash! Unplugging the machine won't help, because it remembers where it was when it gets a power cut!)
Posted on May 30, 2009
Ian Sy
  • 7 Answers
SOURCE: I NEED A USER MANUAL FOR MY ZANUSSI AQUACYCLE 1200
You can download a user manual from here:
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/FX1265W-_E
Kind regards,
Ian
Posted on Nov 29, 2009
news775
  • 699 Answers
SOURCE: hi i have bought a
Check the water supply is ok.
Also check the filters on the water pipe.
If that fails contact the seller to get your money back.
Posted on Feb 07, 2011
I need user manual for indesit wi25
Type your washing machine name into the Google search box and scroll down the list of 'hits'. You'll see your washing machine instruction booklet offered for free as a PDF which you can download in a couple of seconds.
Mar 09, 2013 | Indesit W 123 Front Load Washer
I don't know how to use my whirlpool front loader I purchased second hand today. It is only 2 years old and in lovely condition but I've never used a front loader before. It did not come with an...
When you buy a second hand washer it is important to ask for a demo or a free trial . If this is not done a second hand is always a second owner though it looks new which can be done with some cosmetics.
Check the power, check the display, check the inlet supply, check the door to close and click . When the start is initiated if the water does not flow or activate you will need to check with your seller . take opinion before you go further.
May 03, 2011 | Whirlpool Washing Machines
I rented a home and ive got a washing mashine(simpson esprit 450),so my poblem is how to use it.i have to put washing powder first? and where to put?then what?....pls help
Hi just read your posting.Is your machine the TOP LOADER model or the FRONT LOADER model.Please reply with additional information and I can help you with instructions on how to use the machine.
Aug 01, 2010 | Washing Machines
INSTRUCTION BOOKLET
Hi-
You can download the manual on this link, Just click HERE
Thanks for using Fixya, pls rate solution if it helps.
Jul 16, 2008 | Samsung SGH-D500 Cellular Phone
ARDO TOP LOADER WASHING MACHINE
Click on "washing machines" (below FIXYA)on this website, go to Ardo (if available) type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you hav your manual on line.
And rate me pl.............. if helped
Jan 03, 2008 | Washing Machines
Hotpoint Wd 420
Click on Hotpoint (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
The first usually is for the softener liquid, which has a small window also for the liquid to mix and go down. The second is usually for the main wash (use front loading powders), and the last is for pre-wash, etc. And dont forget to RATE me. There are guys who just read the useful info, and move on..........leaving me sobbing.....
Nov 26, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Zanussi TLE1116W Top Load Washer Logo
53 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
