Question about Acer Aspire 9810 Notebook
My Acer 9810 laptop screen is blank on boot-up, shows just vertical lines of garbage during boot-up but screen visible in safe-mode, anything I can do?
pagebor
  • 2785 Answers
SOURCE: qosmio g30 , problem with boot up screen
try the following
update your video graphic drivers,
try with another ram,
if still you have problem try to repair or reinstall the os
Posted on Jan 17, 2009
  • 38 Answers
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Posted on Jan 31, 2009
sacraty
  • 64 Answers
SOURCE: Acer aspire one not booting
your laptop has been turned off without shutting down. all your laptops registries are probably messed up. the easiest way to do is to reformat your computer or restore it to factory settings. unless you have some important files that you cant afford to lose.
Posted on Feb 07, 2009
cheap to fix
  • 404 Answers
SOURCE: Acer Aspire blank screen
yes its a virus that's blocking explorer
a complete clean xp installation is needed to fix this problem.
rate plz
Posted on Mar 09, 2009
romsky79
  • 822 Answers
SOURCE: Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
Posted on May 20, 2009
The screen on my hp pavilion model f3378h goes blank and all i get are lines that run vertical.
Connect an external monitor to your laptop and see if you still have the vertical lines. If the vertical lines are not visible on an external monitor you more than likely have a problem with your notebooks LCD panel.
If you still have the lines you may be having a problem with your graphics card/chip.
You can also see if the problem happens when you boot to safe mode. If you can get into safe mode you can try reinstalling the video driver for the laptop.
Your last resort would be to try a reinstall of Windows to see if that clears the issue (if all else fails).
-- or --
In the end you may need to contact HP support. I would check to see if your laptop is still under warranty.
Based on the information you have given me it sounds like a hardware issue.
Apr 12, 2011 | Computers & Internet
My acer aspire 9810 won't boot, only the lights on the board are visible but nothing is desplayed, the VGA card, RAMs and Processros were tested and are working well. Thank you for your help
If its giving out a video signal to an external monitor then most likely the display panel needs to be replaced.If is doesn't show video to the external display then your video card may be bad
Jan 21, 2011 | Acer Aspire 9810 Notebook
When are turn on my laptop.. It shows only windows screen with "press f2 to change set up" and "press f12 to change your boot order" at the bottom of the screen. Later, it turns out to a blank screen.
Hi, you haven't said what operating system you have, but here are two options. Restore windows with your windows CD. Or you can boot into safe mode by pressing the Del or ESC key during initial boot, select start in safe mode, from where you can reset your operating system to an earlier time before the problem. Both of these will not loose any saved files.
Aug 07, 2010 | Acer Aspire One AOA110 Linpus Lins Lite...
Blank Screen
HI there.
Try booting into safe mode by pressing F8 while the computer starts up.
If you can get it into safe mode perform a system restore.
If it won't boot into safe mode please post back.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Acer TravelMate 4230 Notebook
My laptop is showing blank screen after restarting
try starting your laptop in safe mode by presssing f8 during the booting process, then check whether its boot or not
Oct 28, 2008 | HP Compaq Presario F750US
HP Pavillion ZV5405 with Black/White vertical lines through screen
Will it boot from a CD/DVD? Make sure the boot sequence is set to boot CD first and then see if it will boot into setup from a CD/DVD. If it will, then maybe try reinstalling windows. Hope this helps.
Aug 21, 2008 | Acer Aspire 5100 Notebook
Open Questions:
See all Acer Aspire 9810 Notebook Questions
Acer Aspire 9810 Notebook Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
