Question about HP Office Equipment & Supplies
How can i install my hp3420 printer using window 7
I need to install as default printer to laptop windows 7 printer Panasonic DP 8016P Workio but i have no cd driver installer, please let me know how
Panasonic WORKiO DP-8016 can be used with Windows 7 System. You may need Windows 7 Drivers. Also, User's Manual & Driver's and installation can be download from the official support site. Windows 7 Drivers and all instructions are available here. (Download the the PCL Drivers with Installer for Windows 7)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 20, 2011 | Panasonic WORKiO DP-8016 Printer
Previous use window xp recently have one note book window 7 our printer is not working window 7 processing the method of driver installed
My dear friend, observe computer peripherals compatibility. If you are telling that your printer is working on windows xp that means the printer designed only for windows xp but some printer right now is supported with different operating system. Anyway download a printer driver for windows 7 if it has and install the software first and plug the printer after installing the software. Have a nice day!
May 30, 2011 | Computers & Internet
Is Minolta Magicolor 2200DL compatable with Windows 7 if not can it be used with Virtual device XP and if so how is that set up?
Yes it does work with Windows 7. The way to install it is NOt to run the Magicolor install routine supplied with the printer. Insteda in Windows 7 start menu, devices , add printer, clik on the ADD printer option (at the top) . Windows 7 will then come up with a suggested list of printers including the 2200DL. Ignore this as iot only allows a postscript driver to be installed. Instead choose the I have disk option. get windows to look for the install disk (or install files if downloaded from the QMS site and find the .inf file. Click on this. Windows 7 will then install the up to date Windows print engine files and marry it to the dteails for the 2200Dl details and you will end up with a Windows 7 driver. This works in Windows 7 home premium and professional.
Robindtg
Feb 18, 2011 | Minolta magicolor 2200 DeskLaser Printer
I have a dell photo printer 720, that I used with my windows xp, but now, I bought a windows 7, , so when I try to connect my printer is not compatible, my question is: can I use this printer with a...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Oct 14, 2010 | Dell A940 All-In-One InkJet Printer
No drivers for Epson Stylus Photo 1200 printer for Windows 7
The driver for this printer comes with Windows 7. Use the "Add a Printer" wizard from Win 7 to install. After that, it should print fine.
Feb 10, 2010 | Epson Stylus Photo 1200 InkJet Printer
How to install LAN Brother MFC-5840CN on Windows 7 when original CD only has XP driver. Windows Update list specifies MFC-5840CN USB, but machine has option for LAN - is the driver the right one?
You cannot use the full driver and software package now. BUT:
Printing is possible, scanning and FAX is not possible at the moment. You download the Vista driver (x32 or x64) from the official Brother site and install it with the Printer Wizard in Windows 7.
Oct 28, 2009 | Brother MFC-5840CN All-In-One InkJet...
Lost driver cd
I am not sure what operating system you are using...XP...Vista etc. But go to this link and choose your operating system and download your driver. It is for the printer you provided.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=75040&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
May 12, 2009 | HP DeskJet F380 All-In-One Printer
Printer
hi lurpak;
are you using the cd installer that comes with your hp printer? if yes, you may try downloading the hp3420 driver on the hp site and try it out. ill wait for your reply.
Jun 02, 2008 | Microsoft Windows Vista Ultimate Edition
Printing,hp deskjet3420
Hi Malcom,
The HP3420 is connected to your PC through the USB port and not through the LPT1/parallel port.
You have to change the port setting. Go to Start, Printers, right click on HP3420, click on Properties, go to the Ports tab, check/select USB, OK.
Alternately, you may have to re-install the drivers for the HP3420 and allow the program to Search for the printer connection. Clicking on the button Stop Searching will auto install it again to LPT1.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Computers & Internet
27 people viewed this question
Seeker5211
Seeker5211
