SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
SOURCE: Instruction Manual for HZ-705
HZ 709 This model# is the closet we'll are gonna get unless I can find my manual and get it scanned. Scroll down to page 4.These instructions will give you a basic idea how this heater works. Good Luck :-) http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
SOURCE: bought heater at a yard sale & says oil filled
The heater should be per filled with oil and sealed allyou should have to do is plug it in and waite about 15 or 20 min for the oil to heat up
SOURCE: Kenwood oil filled radiator heater - digital
My EW6708K stopped working after a power outage (was not on at the time, just plugged in). I couldn't find any info online. So I used my last option: I took it apart. Two screws on the bottom opens the unit's electronics. Two more screws inside to get tol the circuit board. I was looking for a reset button. There was a tiny white “thing” on the circuit board. I pressed it and reassembled the unit. That did the trick! Simple. Just be neat and put everything back the way it was.
