Question about HP Deskjet D2660 All-In-One InkJet Color Printer
I just new printer.But when i want to print using colour,the outcome is just red and blue colour,even the actual colour in the input is green,it will be come out in red colour.How i'm gone to fixed it??
  • 50 Answers
If it is a brand new printer and you are using the host cartridges that came with the printer, then you may face this issue.
You need to try with another set of cartridge.
HP 60 Black Ink Cartridge : part no. CC640WN#140
HP 60 Tricolor Ink Cartridge : part no. CC643WN#140
You may place an order directly from HP ( 1-888-897-8561 OR http://www.shopping.hp.com/webapp/shopping/home.do
After you recv the cartridges, clean inside the printer with a lint free cloth or coffee filter, remove all tapes from the new cartridges.
Install the cartridges and this should resolve your problem.
However if this does not solve the problem, call 1 800 474 6836 for troubleshooting and/or replacement.
Posted on Jul 14, 2010
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Color
printer clolour catridge USE RGB (red blue Green clours) to print a coloured picture it seems that u have used Red and Green colours of your catridge refillit or replace it it will solve your problem suyyam@gmail.com
Jul 22, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can't seem to print the colour red
have you tried updating the printer drivers or cleaning the printer heads on printer properties
Jan 22, 2009 | Samsung CLP 300 Laser Printer
Hp psc 1210 all in one colour problem
The cartridge may be defective. I had that happen so I returned for another and it worked fine
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
My HP PhotoSmart 7762
I have a hp printer photosmart 7762, during traveling my power cable and tried every way I could to buy a secnd hand including buying another similar printer which I failed. Please help me. **** nazymharris@ukgateway.net
Oct 28, 2007 | HP PhotoSmart 7760 InkJet Printer
XEROX PHASER 8550
Do you have the operators manual? Run it through a cleaning cycle. Also Xerox's website will guide you through some maintenance steps. If you are using generic wax, you may have clogged the jets.
Aug 02, 2007 | Xerox Phaser 8500/DN Printer
HP Deskjet D2660 All-In-One InkJet Color Printer Logo
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
