Question about HP Computers & Internet
Hello. . . I have a 2006 HP desk top computer with Vista and the entire screen is black w/message saying Boot Failure, insert system disk. Also previously I recvd an err1err3 message. I've already spent 200.00 and no one can fix this saying the hard drive is corrupted. What do I do?? Help!! Sublime2012@gmail.com Tammy
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
Boot failure message is shown because you have uninstalled any important drivers,deleted any system files or it is a virus infection problem. You need to recover your windows from windows vista DVD. Check it to your dealer.
Posted on Jul 17, 2010
Hp blue screen says "entering setup ..." but it is locked up instead
ok, an A6512p0b PC desk top.
VISTA.
HP media kit,? a real kit not using home made kit? from HP.
New HDD causes the F11 key to go dead (or F10 older PC)
F11/10, is the VIRTUAL install CDs/
HP put the install CDs in its own hidden install partition.
making the f10/11 key run that virtual CD installer.
now you have a new HDD, and guess what, all that is gone.
so step 2 is what, REAL MEDIA KIT. from HP.
HP has a huge pages on this, every step every way possible to restore, at hp.com ever see HP.com?
what worries me is this statement by you/'
"but cannot open BIOS." this is serious all screens must work.
you can remove the HDD and CD drives and BIOS always works
BIOS IS IN ROM, it always works or it has very very serious problems if it is DEAD. BIOS DEAD.
the screen is not dead, you see its works.
like:
  1. PSU bad.
  2. CPU overheating or heat sink bad or fell off.
  3. memory bad, try 1 stick at a time?
  4. other things plugged in to mobo that are shorted..
  5. mobo bad.
  6. GPU card bad or has problems if it has one. see #4
  7. desktops can have lots of things added, i cant see yours. inside/.
the correct kits are from HP, here.
comes with all drivers, and all HP apps. and is turn key.
https://support.hp.com/us-en/document/bph07143
there are other ways to do this, using MS disks and long day of work.
ill not teach that here.
Jun 23, 2017 | HP Pavilion a6512p-b PC Bundle PC Desktop
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
Causes:
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
f-prot.
http://support.microsoft.com/kb/166454/en-us
http://support.microsoft.com/kb/69013/en-us
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
Feb 03, 2011 | HP Media Center m7260n (EG642AA) PC...
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Aug 08, 2009 | Computers & Internet
My hp media desk top computer vista will not boot up i get blue screen with some comands and logo hp invent then screen goes to black screen and has this message, reboot and select proper boot device or...
If you have the boot disks that came with the computer this is the media it is talking about.. After you re-load everything to your computer I suggest downloading AVG antivirus
Jul 10, 2009 | HP Pavilion a1700n PC Desktop
Unable too logg into the system
sounds like a hard disk issue try booting from the original s install disk . the see if you can reapir the installtion
if it still can recognise the disk you probably have a hard disk problem. Eithe buy or get a techical person to call out and check the hard disk for you.
if you have win xp boot to the cd then choose repair at the first menu , when you get to the dos screen type in
chkdsk /f and let it do what it must to complete.
hope this helps
Jan 02, 2009 | E-Machines Emachine T5026 power supply **...
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
My hp compact presario will no boot it is saying boot failure insert disk error message is on black screen and I cannot find my system disk
Did you check to make sure you don't have any discs, cd's or floppy discs in the pc when you turn the machine on?
May 11, 2008 | Computers & Internet
Computers & Internet Logo
127 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
