Question about Samsung LN46A650 46 in. LCD HDTV
We turn on the TV but no picture comes up. The TV
We turn on the TV but no picture comes up. The TV then turns itself off and on again continuously and the only way to stop it is to unplug it.
  • 11,361 Answers
You may have problem due to unstable power supply due to bad DC filter caps, or short circuits in the backlight inverter board that caused the power supply to go into the shutdown mode, those are the two areas to check. You can try disconnecting the inverter board from the power supply to see if other functions of the TV will come back.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 14, 2010
I have a Sony wega old style tv and the standby
The reason that that TV does that is because it needs a new lamp there's a lamp that can be installed in that TV you can search Amazon for the part you need and that should correct the problem especially if you have sound and no video
Jan 24, 2018 | Televison & Video
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
When I first turn on my Technika tv I get sound but no picture. After hitting the top of the tv it comes on. After a further few minutes the picture freezes and eventually fades away. Further hitting of...
The dreaded loose connection syndrome, this could be easy or hard to trace, only solusion is checking circuit boards for bad connections , it may be also capacitors in power supply neading replaced, not a novice repair
pete
Nov 11, 2010 | Televison & Video
My Philips 36'' CRT TV won't turn on.
Hi - Yes. There are high voltage components in your CRT TV that only a certified TV repair shop should repair. And the cost of that would likely be over $100 so you are definitely better off getting a new LCD TV. You will also save a great deal of electricity with your new TV, my 55" only uses $19 worth of electricity a year. And the picture is much better as well.
Have fun shopping!
May 05, 2017 | Philips Televison & Video
Sony kv 27V15: No picture but sound
Hi! the trouble indicates that your television's picture is the culprit, have your unit check by a qualified technician for verification.
Sep 12, 2009 | Sony KV-27V15 27" TV
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Tv turns off when I first turn it on
hi this s grizmofreak
solution to above problem
this s because of the secondary emissions of picture tube, and once the supply stops the emmissions from the picture tube wont stop for few seconds and horzontal scannin problem.
please do rete me on the above solution.
Feb 02, 2009 | Televison & Video
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Samsung LN46A650 46 in. LCD HDTV Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
