Question about Whirlpool Refrigerators
Won't stop beeping every few minutes -- doors are closed
    President:
  • 1,099 Answers
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Then plug-in and follow instructions. Things will be good, but if otherwise.
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it
Good luck...
Posted on Jul 14, 2010
2012 open range refrigerator is closed but won’t stop beeping. It is acting like it’s open. Please help. Thanks.
I would look for some sort of door switch that is not engaging. There has to be something that tells the unit if the door is open or closed. This is the simplest and cheapest place to start.
Apr 28, 2018 | Refrigerators
Oven keeps asking for probe
connect probe and insert probe
Jul 26, 2015 | Kitchen Ranges
Beko freezer TZDA 619 F
The beeping noise is a warning that could be door open, hi interior temp or maybe the compressor is overheating. You might want to inspect the cooling fins for excessive dust or dirt that might be a problem.
Jan 01, 2014 | Refrigerators
Fridge/freezer beeping every few minutes
it beeps to tell you that the door is open and has been for about 5 minutes and that it won't work efficiently + it could be that you fridge is on an angle (leaning forwards) so just adjust the front feet or put cardboard underneath or that the magnet has gone and you would need to get a new seal from hotpoint. if you contact them, they might bfe able to tell you what you need.
Jun 12, 2012 | GE Refrigerators
Fisher Paykel ED56AU Clothes Dryer. After pressing "Power" then "Start", dryer would stop after a few minutes or sometimes a few seconds. Tried turning off at the power point etc. No...
hi - the beeps are an indications the door has not closed proper - It will seem the door switch could be faulty?
you could try adjustments - door hinge cover has door switch behind - loosen and see if seats better. You may have to replace the door switch mechanism to fix the problem.
Jul 12, 2011 | Dryers
I have a Frigidaire Beverage Center Model FFBC46F5LS It was installed on Friday and worked fine until today (Sunday) where it has started to beep constantly. If I press the light button at the bottom of...
I recently purchased a Frigidaire Beverage Center and had the same constant beeping issue as strivieri. I found my problem to be the door sensor. The door sensor is located on the lower bottom right of the unit and there is a metal plate mounted on the swinging door that is suppose to push that sensor in when the door is closed. However, this was poorly designed as it fails to do its task. I had a few adhesive floor protectors laying around that I used to stick to that metal plate that gave it the extra thickness needed to push in the door sensor when closing the door.
I hope this helps anyone else there having the same issue.
Nov 14, 2010 | Frigidaire FFBC46F5LS
My refrigerator beeps 5 times every few minutes and won't stop. The doors are closed. I forgot to turn it back on when I cleaned it yesterday so it was off for about 16 hrs. When I turned it back on, it...
The refrigerator is probably beeping because it is too warm. It has a sensor thaat will make it beep to warn you if it gets too warm. After being off for such a long time it will take a long time to get it cold enough again to stop the beeping. Give it time and it will stop.
Nov 16, 2009 | Electrolux Refrigerators
Warning driver door not shut, beeping every few minutes. door !
either door ajar switch is bad or door jamb push button is bad or not plunging all the way in.
May 22, 2009 | 2004 Renault 181
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
How long does the door alarm continue beeping after the door has been left open for 2 minutes? We have Model PDS22MBWCC. Thank you.
The door alama will sotmd if either
door is open fin" more than 2 minutes.
The beeping stops when w)u close
the door.
May 09, 2008 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
