Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Makita LXT 18v cordless Jigsaw: Does not work, the battery is loaded the light turns on when i press the trigger, there is a noise but the jigsaw only moves slightly. Any clues? it is brand new.
    Champion:
  • 313 Answers
Might be cam or eccentric problem
Posted on May 29, 2008
Stopped working
battery or electric and what make?
Nov 29, 2015 | Drills
Bjv180 blade snapped how do i remove it?
Hi
I don't have the actual answer, but this may help you!
http://www.makita.nl/images/files/onderdelen/nl/BJV180-TE.pdf
Just to state the obvious, you have slid the plastic piece to undo the blade holder?
See page 6 of the manual here
http://wiki.makespace.org/images/b/b1/BJV180_manual.pdf
Hope this may help.
If all else fails I would put some oil into the blade holder and try wiggling the holder. Failing that a bit of wire and some fine pliers. Failing that a good blast of air from the aircompressor to try and blast it out.
Good luck
May 25, 2014 | Makita Bjv180 18v Lxt Cordless Jig Saw,...
Why will a makita Li-ion 1.3ah battery not fit in other makita tools?
Some of the Makita 18v LXT tools require the BL1830 3.0AH battery and are designed that the 1.5AH battery will not fit.
Jan 12, 2013 | Makita 18V LXT Lithium - Ion Cordless...
Btd144 when pull trigger light flashes drill dont go
The battery itself has a deep discharge protection .
Or the electronic or the battery its a new
phenomenon where you can have bought electronica and a triggerswitch and you have measured the electric field on 0.3 ohm on both 2x3 coils and the battery measured on maybe 15 Volt and it do not give nothing yes the lamps burned , but there was not an charger in my case delivered so i am also waiting for this problem by a Makita Jigsaw because a colleague has allready a electronic circuit and switch ordered and tried with that battery and an other battery but no life at all, so a new battery should may be working. or a broken or new damaged electronic part was delivered. that brushless tools are a young technical thing, many brands have.
the teething problems out, by the switches and the power mosnfets(panasonic) Makita is new for me this comparable problem a have also have yesterday.
next week i know more about a possible solution.
Makita BTD144 Lithium Ion Impact Driver Brushless Motor Parts
Sep 09, 2011 | Makita BTD144 18Volt LXT LithiumIon...
Makita 18v lith ion battery not charging
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper or wire wool. Apply light pressure as otherwise you may remove the chrome or nickel plating on the contacts.
Apr 04, 2011 | Makita BDF452HW 18V Cordless Lxt Lithium...
Where can i buy new case for makita jigsaw BJV180 LI-Ion
you can go to Makitausa.com and buy direct or they have a dealer locator on their site so you can buy locally.
Jun 29, 2010 | Makita BJV180 18V Lxt Lithium Ion Cordless...
My Makita BJV180 jigsaw will not do elliptical cutting even though I turn the lever to the elliptical cut position.
this saw has 3 orbital settings and one straight line setting .. in orbital mode the blade moves forward slightly on the up stroke and back on the down stroke .. it may be difficult to see and may not be pronounced without a load ...
Nov 12, 2009 | Makita BJV180 18V Lxt Lithium Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
197 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
