Question about Simmons 511072 3-9x32 A/O 22 MAG Riflescope - Matte Black
3-9x40 magnification ring just spins
Simmons 21829sp 3-9x40 magnification ring just spins. How can I take this apart to replace the ring.
  • 2,100 Answers
Without seeing the scope, I can only guess, the zoom ring has lost it's screw, The rear lens will come off easy enough, then peek inside for a loose screw, if you find it, you will see a long twisted slide on the side of the tube just inside, turn it till you can see where the screw went. It should be a set up something like that. when you turn the zoom knob it slides a lens front to rear fast, and it rides on that screw, Check it out.
Posted on Jul 20, 2010
Testimonial: "Thank you for the good info. You are correct. I have found that the screw is stripped. Thanks again."
Will a 3-9x40 muzzleloader riflescope work on a 30-30 rifle
Yes, Any scope will work with any rifle as long as you have the appropriate base and rings.
Dec 30, 2013 | Nikon Inc Nikon INLINE XR 3-9x40 MATTE...
I have a Simmons Model ATV 4515 rifle scope. other
Your scope has 5 adjustments:
1. Eye piece focus - used to focus on the reticle.
2. windage adjustment - should be on the R side of the scope, adjusts lateral impact point.
3. Vertical adjustment - the top turret. Adjusts vertical point of impact.
4. Power ring - adjusts the magnification of the scope.
5. AO ring - Parralax adjustment - used to focus the scope at specific distances. Most markings are not exact, you should set it at the range you are shooting and fine tune focus when you look through the scope.
Sep 06, 2013 | Optics
Looking for instruction manual for Simmons model # 6441 telescope
looking for manual on a simmons 6441 astronomical telescope.we can not see thought it..would love to look at the star and the noon. with my 6 year grand kid name orion..he is excited too!!! help use please!!!!!
Aug 11, 2011 | Simmons 510513 3-9x40 Blazer Riflescope -...
At 30 yards im 6 inches high to be dead on at 150 im shooting a 270 and i have never had this problem before
the scope is mounted to high on the rifle try a lower set of mounts,,,this is called parallx error and is very common if you have high mounts,,,,
Nov 24, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
Loss of focus when izoom in
This typically means that you are have exceeded the scopes ability to focus at the distance that you are shooting. This scope is optimized for 50 yards and will function well at all magnification settings. Closer than this optimal distance the higher magnifications may present problems with blurring. Many scopes have a "parallax" adjustment that changes the optical focus to correct this problem. Several of my 22 mag scopes have this adjustment on the objective bell. You simply set the indicator line on the appropriate yardage indicator (making minor adjustments to fine tune focus). Hope this helps
Sep 16, 2010 | Simmons 22 Mag 39X32 with Rings
What does setting 3x9x40 mean?
3 x 9 indicates that the minimum magnification is 3 times normal, and the maximum is 9 times normal. The last number (40) indicates a 40mm objective lens (the one furthest away from your eye). This is an indicator of the scopes ability to gather light from the environment. The larger the objective lens, the better it can gather light, and the brighter the view appears.
Sep 12, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Simmons 8x32-44ao rifle scope
Is that the "Prairie Master"? I think Simmons is pretty uniform in that range of scopes--elevation adjustment should be the top dial and windage is on the side. The zoom locking ring should be in front of the eyepiece, with the zoom ring just forward of that.
You can download a generic Simmons scope manual from the Simmons site at this link: http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Mar 31, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
Instruction manual
go online with simmons and request a mauual for the scope. there will also be a tech support number on there web site if you want to call them
Mar 28, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
Who is the manufacturer of the Cabela's Alaskan Guide 3.5-10x40 scope? I am having problems with it and not sure where to get fixed. Cabela's doesnt repair them. The crosshairs rotate a little when I turn...
i'm not sure but most probably, a rebranded chinese scope. as most are these days.
its not economically viable to repair these scopes if it requires a re-gas and re-seal.
if its under warranty, get it replaced or buy a new one.
to get it fixed would cost more than the scope is worth
RobbieP
BSA Owners Group
Nov 19, 2009 | Simmons 510513 3-9x40 Blazer Riflescope -...
Simmons 511072 3-9x32 A/O 22 MAG Riflescope - Matte Black Logo
321 people viewed this question
Top Simmons Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a Simmons Optic Expert? Answer questions, earn points and help others
