I have a vulcan 4690001 approx 10 yrs old and the heater just stopped I cannot see the pilot light and the fan is not going
3 Suggested Answers
  • 1417 Answers
SOURCE: I have moved into a
Here are the solution below to solve the problem on your on the mater of do it your self one after the other (step by step).
The first sign of trouble with your water heater's pilot light is usually a cold shower. Your heater's pilot light allows the burner to cycle on and off while maintaining the water in the tank at a constant temperature. When the pilot light goes out for any reason, the thermocouple closes the burner's gas supply valve to prevent gas escaping and filling your house.
When your pilot will not light or does not remain lit, you might be able to save the price of a service call by taking a few minutes to troubleshoot the problem.
Difficulty: Moderately Easy
INSTRUCTION
  1. 1 Remove the pilot light access cover. It is located near the bottom of the tank. If you smell gas, do not attempt to light the heater. If the smell does not dissipate, replace the heater's control valve before proceeding. The control valve is the box located by the access cover. It consists of the on/off/pilot dial as well as the thermostat dial. Consult manufacturer's documentation for replacement instructions on your model.
  2. 2 Turn the thermostat on the water heater to the lowest setting.
  3. 3 Turn the gas control valve to the "Pilot" position.
  4. 4 Inspect the burner area with a flashlight. Clean out any dust or debris before attempting to light the pilot.
  5. 5 Press the gas control valve down in the "Pilot" position, and hold the flame from your match or lighter underneath the pilot light.
  6. 6 If the pilot fails to ignite, check the gas supply to the heater. Make sure all supply valves are open.
  7. 7 If the gas supply is good, the pilot light's orifice or gas jet might be plugged. The orifice is the small tip attached to the pilot light's gas supply tube. Use a small wrench to remove it. Inspect the tip and remove any obstruction by tapping gently against a hard surface or blowing through it. Once you are satisfied that the orifice is clear, try lighting the pilot again and proceed to the next step. If it still does not light, replace the gas control valve.
  8. 8 Remove the flame from the pilot light as soon as it ignites. Continue to hold the gas control valve down for at least two minutes to allow the thermocouple to heat up. The thermocouple is the small metal rod located directly above the pilot light. It is designed to allow the burner to operate only when the pilot light is functioning.
  9. 9 Release the gas control valve. If the pilot light goes out, check the fittings between the thermocouple and the gas control valve. A loose fitting to the control valve can keep the thermocouple from operating properly. If the fittings are tight and the problem persists, replace the thermocouple.
Thank you and thanks foe using fixya.
Posted on Oct 15, 2010
  • 586 Answers
SOURCE: Hi, I have a vulcan
When the fan of your heater does not turn on and the igniter lights but then goes off, then it means there is a problem with the unit of the machine.
The problem with the furnace is that the element of the furnace is bad and need to be replaced. Also check the relay switch of the furnace, that way you will be able to fix both the fans problem and the ignitors also.
Hope this was helpful to you.
Goodluck
Elect_Comp
Posted on Jul 04, 2011
Vulcan wall heater gas issues...
The igniter may be bad and needs replacing.
Jul 01, 2017 | Vulcan Heating & Cooling
Hi i live in reservoir melb vic i have a old vulcan fireplace gas heater Cat 9-14 1972 seriel no 4442. AGA OR ALP GA App no 1805-002 It has 5 white heat elements behind the glass front approx...
The part you described is the heaters Control Valve for your Infrared Gas Heater. It is an expensive part to replace. If one is still available for your older unit.
You failed to mention where (what country you're in), but Vulcan has been popular in Australia for many years, So I'm assuming you're in Australia.
Below is a link to contact information for Vulcan in Australia, b region. Hope this helps you find a service technician.
http://www.vulcan.com.au/contact.htm
l
Jun 01, 2011 | Heating & Cooling
I have a Vulcan Freeloader that is over 10 years old. The pilot does not stay lit when I release the red button. Also, the pilot flame is orange. What can be done as the main burner would not work when the...
The pilot assembly is stopped up. It will need to be taken apart, blown out or cleaned and re-intalled. The yellow, lazy flame is preventing the thermocouple from getting warm enough to allow the main burner to ignite. Hope this helps.
Jan 20, 2011 | Heating & Cooling
Can't seem to ignite pilot on a 30 year old vulcan heater. Same problem every year as winter is approaching :) Usually works fine once pilot is on though.
It's probably just a dirty pilot orifice (or a spider web), if it's been off since last winter. Try using a can of compressed air with attached straw (like you use to clean computer keyboards) and blow out the dust from the pilot orifice in the pilot assembly, which is where you light it. That should do the trick. Good luck! Douglas
Jun 07, 2010 | Heating & Cooling
The pilot light has gone out on an old Vulcan gas wall heater. How do I turn it back on?
You probably need to replace the thermocouple before you will be able to get it lit.
Oct 14, 2009 | Vulcan Heating & Cooling
Pilot light keeps going out! difficulty lighting
Dirty pilot, you may need a contractor.Tom
Jun 18, 2009 | Heating & Cooling
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
