Question about LG LWHD2500ER Wall/Window Air Conditioner
I just purchased a new 2500er unit. the rear of the unit is 12 inch away from the adjecent building. the unit turns off completely. there seems to be a sensor that turns off the unit when there is excessive back pressure. is there any way to by-pass it? thanks. mike.
    President:
  • 1,515 Answers
Hi Mike, what is happening is the unit is shutting off on high head pressure as the air that the condenser fan pulls across the outdoor coil is apparently being restricted by this building. You can't very well move the building to make it work. Normally, 12" would be enough room, but not in your case. You can look on the schematics and locate the high pressure switch. Its just a very simple switch that has a wire in and the same wire out. The switch is a single pole switch opens the contacts on high head pressure. Even though you don't have a high head problem, the switch is getting the blow back from the building causing it to shut down. The switch in the schematics will say HPS . The wire should be red in color and there will be 2 wires, but its the same wire. Goes in and out at the top. It will be brazed to a smaller copper line. The low pressure switch will look the same, but will have blue wires coming out the top. The voltage should be 24 volts. Unplug unit, find the switch, cut the wires leaving enough to reconnect if you need to in the future. Strip the insulation from both ends of the wire and tie it together, using **** splices or wire nuts. The unit will now stay running. Just wash this coil outside once a year to keep it clean. This is the way to by-pass it. Your only other option is to move the unit or have a transition duct made and mounted to the back at a 90 degree angle. I don't believe you will have enough room to put one on with only 12" to work with. You can see the switch from outside on one of the high pressure lines, getting to it will be difficult. I know its new, but to get to it you may have to use sheet metal cutters to make a square to reach it and cut a piece to screw back over it. We do this in the field when needed. Please keep me posted on this and don't forget to rate me. Please be kind when doing so, as I know you will. Let me know the out come. Thanks for contacting Fixya.com
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Jul 14, 2010
Testimonial: "Thanks i appreciate the support :-)"
  • Robert Horton
    Robert Horton Jul 15, 2010
    Thank you for the outstanding rating, I am here to help you.
    Shastalaker7
Ainol Novo 10 Hero 10 won't turn on :( it appears dead :'(
Sounds like it is not charging.
The unit will power on momentarily if low batter but power off straight away
Get an electrical competent person to check the output of the power unit or use know good unit.
Dec 06, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
Rear Driveshaft turns between an eighth and a quarter inch back and forth when rear end is lifted off the ground. There is a knock when I take off from a complete stop and when I come to a complete stop....
my advice throw that car away it will end up killing you and yes pls do not buy a car over 60,000km on the clock chances are the higher the reading the more the engine is finished
Sep 12, 2013 | 2004 Ford F250
I have a Magic Chef compact fridge. There was a lot of ice build up in the freezer compartment. I attempted to defrost it last night, but I also tried to break away the ice before it was completely...
either the defrost heater element or defrost thermostat is open behind the rear wall where all the ice buildup was and is bad or the defrost timer in the front area isn't working to defrost the unit on a 12 hour schedule,you will need to test each component
Oct 14, 2010 | Refrigerators
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
Range unit stands too far away from wall
There are mounting plates that recess the plug in the wall. Hardware stores have them in the electrical parts department.
Apr 15, 2017 | Frigidaire FEF336BC Electric Kitchen Range
RCA VHS-C screen for sculpture
The resistance of hte wire is not the major problem. While it will degrade the signal somewhat, the main problem will be outside interference. You would be better off trying to hide the camera closer to where the screen must reside and usinga ribbon cable only a few inches longer. You will need to find a service manual for that model to get the pinout of the cable.
Good luck.
Dan
Jun 06, 2008 | RCA CC6374 VHS-C Analog Camcorder
Kitchen Aid Model KBLC36MHS01
The drain under the evaporator is frozen/plugged.  You can take the back panel inside the freezer off and run hot water down it to thaw it out completely and this will solve your problem.
Oct 17, 2007 | Refrigerators
LG LWHD2500ER Wall/Window Air Conditioner Logo
218 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
