Question about Tram TR50 Professional Microphone
Wiring want to change my trams from lemo connectors to xlr and 1/8 " mini connectors
BX10s has a hum the moment it is turned on whether there is an input connected or not.
Make sure the input cable in good condition and properly installed in the input socket. If in doubt, try changing to another cable.
If the inputs using XLR connectors, make sure the XLR pin configuration is correct (this if you make your own cable with XLR connectors). At the XLR connector, pin1 male connector must be connect to pin 1 female connector, and so on.
If the hum still is not lost, you can bet there is a problem in BX10s. Of course it can be repaired by experts. Unless you have other plans.
Aug 24, 2015 | M-Audio BX10S 10" Studio Monitor Speak
Antenna GPS Tram 1655 is compatible with GPS FURUNO?
If the Furuno unit you're referring to uses a GPS antenna with a coax (i.e. GP31/32) then the Tram antenna will work but the connector is wrong. The Tram antennas usually come with BNC connector and Furuno uses a TNC. Will need an adapter.
Oct 14, 2013 | Furuno GPA019S GPSDGPS HField Antenna...
Connecting r21s to laptop
The input to the laptop usually requires a stereo or TRS type 1/8 inch plug If the mic has an XLR type connector, you need a special cable that connects the XLR pins 1 and 3 (adjacent pins) to the shield of the 1/8 inch plug and pin 2 of the XLR connector to BOTH the tip and ring of the little stereo jack. Such a cable is not commonly available so the best is to make one from parts you get at Radio Shack.
Mar 12, 2013 | Samson R21S Microphone
Audio-Technica freeway 200 Series VHF Wireless System - I had problems connecting the wireless system with a quarter inch to a xlr. The sound system made a very loud disturbance sound. What cable do I use...
XLR connectors are a two-wire plus ground system. Using a 1/4 inch to XLR adapter may not connect the wires correctly to your sound system input.
The A-T Freeway 200 Series has a 1/4" output jack. This would indicate a line level. A cable to connect the tip of the 1/4" jack to pin 2 of the XLR and the sleeve of the 1/4" jack to pins 1 and 3 of the XLR should work. The XLR should be plugged into a device that accepts line level.
Ideally, you should plug the 1/4" into a 1/4" or RCA jack that is designed for line levels.
Dec 14, 2010 | Audio Technica ATM33A Fixed Charge...
I need to know how to wire an xlr y adapter
I always solder it this way.
Take a female XLR connector, two thin sym. cables and two male XLR connectors.
Solder both cable parallel in the female connector and the ends on the male connectors.
This way you get the same signals on both inputs of your amplifier.
Regards,
Gerard
Oct 26, 2009 | Behringer EUROPOWER EP2500 Amplifier
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Don't know the conections of blue or red
If we're talking about the microphone cable wiring on a low impedance mic remember this. Cheap mic cables with XLR's on both ends often have no standard color code to follow. True pin 1 is ALWAYS ground (shield wire) but the other two wires could be any color of the rainbow. Look for small numbers beside each pin of the XLR connector and make sure that pin two on one end of your cable, is also pin two on the other end as well....etc. Special note: The XLR connectors set screws have reversed threads and it's the same for the XLR male plug in the bottom of the microphone as well.....Glen
Dec 24, 2008 | Shure Beta 58A Professional Microphone
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Tram TR50 Professional Microphone Logo
1,060 people viewed this question
Top Tram Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tram Audio Player and Recorder Expert? Answer questions, earn points and help others
