Question about Refrigerators
We lost power last week and my fridge/freezer will not stay cold...the light comes on, the fan blows, the fridge makes the same noises ..like when it worked properly See less
Thiis a common problem. When the power went out your freezer partially thawed and the evaporator coils got moisture from condensation on them. When the power came backon the water on the coils froze, blocking airflow over them. Simply thaw your freezer out completely for one day with the door open so things can dry out and then plug it back in. It should work fine after that. Good luck!
Posted on Jul 14, 2010
My freezer (upper) works but my fridge (lower) doesn't. There's nothing clogging the vent. What could be the problem? Thank u!
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and are not torn or ripped. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the f
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some are behind the cold control cover. Once you locate the defrost timer, slowly turn the screw likeknob in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater (s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can continuity test the defrost heater for continuity or test for 120 volts to the heater(s). If you have no power to the defrost heater (s) you can also bypass the defrost thermostat to see if the defrost heater will come on, jumper the wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater (s) and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
bobicehouse_88.jpg Defrost timer
bobicehouse_89.jpg Defrost thermostat
bobicehouse_90.jpg Defrost heater
Sep 11, 2011 | Sharp Refrigerators
Fridge too warm: makes ice, does'nt dispense it: dispenses water warm
I know that it is new but this might be your problem
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Since it is new, you should have a warranty and I would see if a repairman can check it free of charge before attempting anything, I don't know your skill level with this type of machine but good luck and don't forget to rate this post, Have a Great Day!
Mar 23, 2008 | Maytag MZD2766G Side by Side Refrigerator
Tip
My refrigerator is running but not cold enough....
on Oct 01, 2010 | Refrigerators
I defrosted the freezer last week and the fridge will not get cold the light in the fridge is working and so is the freezer.
There is nothing that work in the fridge it is just a box everything comes from the freezer. Check if the fan is running this is how the fridge gets its cold air. Check your freezer setting in your fridge. make sure it says warmer fridge. it a door that opens and closes.
Jun 06, 2010 | Refrigerators
Refrigerator won't get cold enough
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section . For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Kenmore Refrigerators
Not cooling as normal 2008 summit ridge reserve dometic rm 1350 with ice maker. started acting up last year, fans not coming on so I addedan external one .problem solved until recently lost power. now...
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 21, 2009 | Refrigerators
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not cold enough
Hi!!! check to see if you have ice,or frost in the back or your freezer evaporator its on the back if yes your defrost timer is shorted..IF no frost or ice then you have a seal system problem . check your compressor make sure that it is running if its running then you have a leak of freon in the evaporator..Good luck..
Jan 03, 2009 | KitchenAid Refrigerators
Top sections of Freezer and Fridge not Cold at all
check fan is free to rotate and that it has continuity. also check you have power to the fan.
you may just need to replace the fan motor
Oct 19, 2008 | KitchenAid KSRS25IL Side by Side...
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
