Question about Toto Toilet Onepiece Ultramax MS854114SL.12
After the tolet is flushed it will make a hissing nose for along time.What can I do to cure this?
    Guru:
  • 81 Answers
It might be the issue with the valve from where the water gets in the tank, get the washers replaced, or you might want to open it and clean it a little.
Regards,
Posted on Jul 14, 2010
An article in the Washington Times titled The Hushed up solution for all diseases, saying that taking the right nutrients can cure many health problems
One useful book is "The Cure for All Disease" by Hulda Clark. Some of her ideas are conversational. I have used the gall bladder flush and it flushed lots of small gall stones. Dr Hulda Clark Welcome
Jun 24, 2014 | Computers & Internet
Problem with a PF/2 Energizer (pressurized) toilet. After the flush and the refill... a small stream of water keeps sipping and hissing out from a small tube located towards the bottom of the housing...
there must be some dirt on the seat of the valve as when water is turned off and on sediment , dirt can plug up small orficies take apart the valve by getting a schematic from the manufacturer online to take it apart
Sep 14, 2013 | Home
Hissing sound after flushing a flushmate
The washer that shuts the water off is failing. It shut stop incoming water completely when the tank is full.
Jan 11, 2013 | Sloan M-101526-F Flushmate?® Complete...
It take about three time for the trip lever to flush the tolet what my trouble shooting for this
The round thing in the center that the metal rod pushes down on can be turned...turning it counterclockwise will make it higher and get you flushing...
It may take a bit but you can get it adjusted so that it will flush everytime..
heatman101
Aug 07, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
How do i replace the tolet seat
the seat has two bolts that go straight thru the bowl at the back of the seat just loosen the nuts on bottom of the bolts replace same way you took it off
May 09, 2010 | Toto Aquia II Dual Flush Toilet
My toilet continuously stops up when flushing. Is this a problem with the leveling of the toilet??
WELL A TOLET SHOULD SIT LEVEL,BUT THE SHOULD NOT BECAUSING IT TO STOP UP ,UNLESS THE FLOOR IS THAT WEAK OR IT IS REALLY UN-LEVEL.IS THIS A NEW INSTALLATION?MAYBE SOMEONE DIDN'T PUT THE WAX RING ON RIGHT,BUT IT REALLY SOUNDS LIKE SOMETHING FELL INSIDE THE TOILET,ALOT OF TIME YOU NEED TO REOVE THE TOILET AND TURN IT UPSIDE DOWN TO SET WHAT IT LYING IN THE TRAP.ALSO YOU CAN TAKE IT OUTSIDE AND FLUSH IT THRU WITH A HOSE,
Apr 15, 2010 | Kohler Home
Poor flushing
Make sure the water level is the same in both tanks, so you know the water volume will be the same for both units when flushing. Next, hold the handle down for the full flush release to make sure the flapper (in the tank) is not closing too soon and cutting off the full water volume needed. Next, would be to get a tolet snake reamer (buy the cheapest one) and run it through the toilet bowl 3 or 4 times always turning clockwise while entering and while removing. If all this does not cure the problem, then you probably have a defective toilet outlet hole that was made too small when the toilet was formed. The outlet hole must be minimum 1 5/8 inch diameter (most are between
1 3/4 inch to 2 1/4 inch diam.) . This is an occassional industry problem; I have seen it several time over the many years. To confirm this, you need to remove the toilet and measure the hole, or get flush balls of 1 5/8 inch with 4 ft. string attached. If the ball flushes and takes all the string slack, then the hole is at least correct minimum size. If ball does not completely flush after 3 tries, then there is some obstruction or the hole is too small and toilet it therefore defective. Goodluck, Macgivor
Jan 27, 2010 | Pegasus Technologies Elongated 2 Piece...
Jucuzzi era bk 37 959 just installed 6 weeks ago , I have to use
when it was installed the wax ring was most likely installed wrong or has moved and is blocking drain it cost 5 or 6 bucks to replace. thank you for for useing fixya please rate me
Feb 26, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
When i get up to 30mph to 40 mph my car spuders
Check fuel filter and fuel pump, also check your fuel regulator. If all those check out fine then check your plugs, and wires. You can also check your compression to make sure nyou are getting proper compression
Feb 11, 2009 | 1996 Ford Thunderbird LX
Ionic Breeze - Black Quadra won't stop hissing
I have the same problem. The one thing that I DID notice is that it seems to occur more often in winter. Thus, I attributed it to dryer air conditions--too much static electricity being the culprit. With the unit off, I sprayed a fine mist of water into the housing and that cured it for a (albeit-short) time. Best solution would be to increase the humidity via a humidifier...
Jan 30, 2009 | Air Purifiers
Toto Toilet  Onepiece  Ultramax  MS854114SL.12 Logo
467 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
