Canon PIXMA MP530 All-In-One InkJet Printer Check Ink U071 M Magenta Ink is wrong spot, but it isn't. I have checked several times, taken it out, put it back in, replaced ink cartridge, but it still tells me the same thing.
  • 655 Answers
Your cartridge should must be sitted well at the printer head. check it out and clean it.
did you make a hard-reset, if not yet try it.
  • remove data cable from print
  • switch off your printer
  • remove power card from printer and wait atleast 3-5 min to clear the error message que from printer memory.
  • after 3-5 min, make all connection as well, and turn your printer on.
Thanks
Iqbal
Posted on Apr 20, 2008
Canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
Jan 24, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Red does not print. I have deep cleaned several times, it still not print.
red is a combination of yellow and magenta ink, check if you still have the color ink, or clean this unit first otherwise you need to replace the color ink
hope this helps
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Check ink U071 cyan
Are you using genuine ink cartridges? If not, then perhaps there is no microchip on your ink cartridge. You can take the old chip off your used cartridge and put it on this cartridge and see if this solves your problem.
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error U071
Make sure that the inks are not re-manuafactured ones with chips taken off genuine canon inks. It is possible that the wrong chips could be fitted to the wrong colours.
Dec 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
More than "one ink catridge installed" problem with new printer
Try a new Genuine yellow ink in it, if it fails take to canon dealer for free warranty repair.
Jan 12, 2008 | Canon PIXMA MP530 All-In-One InkJet...
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
339 people viewed this question
jasbo
jasbo
