Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
We lost power. now I have a solid A. phone will not take incoming calls. I tried to unplug it still no use
  • sndmn17 Jul 14, 2010
    I tried would not accept **
    still does not work still has solid A
  • 1,555 Answers
At this juncture I would ask you to follow the procedure mentioned below. It will fix the issue. In any case the procedure is not meant for your phone then kindly do let me know the model and make.take the handset out of the base, and any spare battery inside the base. Press (**335782) on the base to de-register all of the handsets at one time, then register the handsets again.
It didn't work. So I called tech support. Turns out they forgot a step in the directions they emailed me. You have to be in a certain menu for the reset code to have any effect. Here are more complete directions:
Remove the spare battery (if any) and handsets from the base station.
Navigate in the menus to the "base settings". Your screen should say "ringer volume, ringer melody, keypad tone, tone/pulse, ..."
Punch in the reset code (including the stars): **335782
Wait for the phone to restart itself (about 5 seconds).
Re-register all of your handsets.
Posted on Jul 14, 2010
    Model L # IA5854 SN CY454892237
    vtech 5.8 single handset
  • Aruna Singh
    Aruna Singh Jul 14, 2010
    Have you removed it from the base and the batteries. Remove it from the base and also batteries and keep it like that for 15 minutes and then install again.
  • 19,396 Answers
Hi.
Hi.
Simply unplugging power is not enough, you have to reset and re-sync the whole system, this is done restetting and synching back the handsets to cradles.
  1. Disconnect all base-units power cords.
  2. Disconnecphone cable.
  3. Remove batteries from all handsets in the system.
  4. Wait ten minutes.
  5. Connect back phone cable first.
  6. Put batteries back in handsets.
  7. Place handsets on cradles.
  8. Connect the cradle power adapters to main socket.
The system will reset and hadsets will synchronize to respective base units.
If that does not work, one of the base units may have been damaged by power surge. In that case contact VTech at the number listed on owners manual.
Regards.
Ginko.
Connect Phone and I/F module , "incoming call" displayed couldn't hang up.
try recycing the power on that...hook up the two modules with power off, then turn power on..it is possible that connecting them while on, would glitch the system
Oct 22, 2008 | Polycom SoundStation2 Audio Conference
My cell phone has lost .please say how to stop incoming & outgoing call for my phone
You have to inform your service provider of the lost cell phone and request them to block incoming/outgoing calls.
Jan 13, 2010 | Sony Ericsson W200i Cellular Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Lost power and need to reprogram lucent 18D.
Call in a vendor. Your system has lost all programming. Voicemail is goofed up to a point.....
The entire system needs to be reporgrammed.
Jan 07, 2009 | Lucent PARTNER18 Corded Phone
Skype phillips voip 841
Unplug power cord of base , then power on.
Also unplug the handset battery , and set the battery back .
Basically, it is software jam
Sep 29, 2008 | Skype IM
RCA Executive SERIES PHONE 25202RE3 had lost the display for caller id etc, LEDS on buttons not lit whne select opyions such as speaker and hear a clicking when the phone is plugged or unplugged from...
A faulty power strip which the hone power supply was pugged into resulted in no power to the phone which ran down the AA batteries. Replaced the 3 batteries, display returned and replaced the power strip. All is back to nornal.
May 29, 2008 | Lands Phones
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Phone won't ring
Hi Melissa,
The phone system (cpu, Brains, Switch) is set for auto answer on your Ext. Either power was lost, programming changed or something along those lines. It is global, so if a call "rings" @ your phone, (any call) you can just lift the receiver and speak.
It sounds like the associated phone lines ringing in "lost" memory of your extension. Therefore it must be programmed or in the case of a toshiba system it has a software "glitch or bug". usually due to "I don't know". So I usually find a change was done to ringing by the vendor or just power loss to the system.
there are a million variables because it was manufactured in asia usually. I would need some more info. to be sure. I can tell you it is NOT your phone. try to reset the phone by unplugging for a minute , if no luck you will need the vendor to reset your Ext. with a laptop or do it yourself with the codes from the main or switchboard ext. I am sure I can give you the info to do this and make it ring again, but you are best off calling the dealer in case fat fingers get wild . you could do much harm by trying by one wrong entry and it is what I call Jinglish ( Japanese English or bad translation) in the manual. $80 or so is worth it , mostly if someone was out to change stuff while you where gone.
Or jus unplug the phone system and wait 1 minute before plugging it back in,  that will reset the system kind of like rebooting windows and forcing it to re - load the system.
Good luck, let me know.
Bob
Oct 18, 2007 | Toshiba DKT-2010 Corded Phone
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
