Question about Mtd 22" Yard Machine Push Mower
Why do grass get stuck in lawnmower than it starts to turn off
BEFORE TIPPING MOWER IF FOURSTROKE read manual to find out whic way is safe to tip do not assume yor tipping it the right way as this could lead to disaster as a friend of mine found out
Posted on Jan 25, 2013
    Sniper:
  • 56 Answers
To quote a tip from an old farmer friend of mine; "turn your mower on it's side and take a scraper and a wire brush and remove all the old grass, dirt, and trash from under the mowing deck...once clean, brush the underside of the mowing deck with a generous coating of used motor oil. This will keep wet grass from sticking to the deck and also prevent your deck from rusting out... you may have to do this a couple of times during the season but it really helps...this is also a good time to change the oil and sharpen the blade"... hope this helps... ;-D
Posted on Jul 21, 2010
    Guru:
  • 630 Answers
This can be happening from a couple of reasons, first if your grass is too damp this will happen with almost any mower, wait till the lawn dries out before cutting, you may be cutting the lawn when it is too high, try cutting it twice a week maybe this will help, you may try to raise the cut setting eliminating the amount of grass clippings that you have accumulated, if you are mulching or using the bag be sure the chute is clear, and lastly be sure you are running at a higher speed to push through the terrain.
Happy Mowing!!
Posted on Jul 14, 2010
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
Lawnmower starts under no load but under load it slows down.
Cut your grass more often. It can't handle the heavy load of long grass.
Jan 31, 2011 | Electric Lawn Mower
Is it safe to cut wet or damp grass with this electric lawnmower? Does it have rcd?
Yes, the electrics are well sealed from the wet grass, although wet grass may clog the mower or slow performance.
May 20, 2010 | Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Ride on lawnmower isnt starting.
You may have a bad starter - the solinoid is "clicking" but not engaging. Remove the starter and clean it up and connect it to 12 volts to check if can turn. If not then buy a new starter and replace it out.
Aug 03, 2009 | Garden
I have a sunbeam power drive electric lawnmower wont cut the gras
The motor is failing. A common occurrence in this type of mower.
Jan 22, 2018 | Garden
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
207 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
