Question about Panasonic KX-T7420 Corded Phone
I have a Kx-t7420 panasonic phone system. I have three of my phones that go directly to line 2. no idea why. Can I change this? Also there is so much noise on line 2 that I cannot hear. Is this something in the programing.
  • Panasonic Master
  • 2,460 Answers
Actually, you have a Panasonic TD phone system and a 7420 phone, but no matter. The feature you have is probably "idle line preference" or "preferred Line Assignment-Outgoing". In TD systems by default, you select lines from highest to lowest. If you only have 2 lines and PLA is set, you get line 2 then line 1. You can change it to get line 1 first, or chage the trunk access order. The first is something you can do from each phone, the second requires access to system programming. The bad thing about the first solution is if line 1 is busy, you won't get any line. The second will give you the entire trunk group.
Anyway, from each phone without picking up the handset, press PROGRAM 99 and dial 1301 STORE. That will give you line 1 when you pick up the handset. Just so you know or can change it, 11 is none, 12 is idle line, 13xx is specific line and 1+the intercom is intercom. Pick up the handset and drop it back down to exit programming.
As far as the noisy line, it's probably a central office issue. It's hard to test as that line is the outer pair of the jack that plugs into the phone sytsem (RJ-14 pair 2), but you can probably take a regular phone and test it at the demarc point.
Carl
Posted on Jul 14, 2010
ON PHONE KX-T7420 NEED TO CHANGE HANDSET RINGTONE . WE HAVE FOUR IN ONE OFFICE AND ALL SAQME RINGTONE.
The phone has 8 ring tones. From the idle phone, press PROGRAM and dial 99. Press the intercom or a CO line button TWICE and dial 2-8 on the keypad (1 is already default). When you're satisfied with the tone, press STORE. You have to do this for each line and the intercom you want to change and you need to do this at each phone. Pick up the handset and drop it back down to exit programming.
Carl
Aug 11, 2011 | Panasonic KX-T7420 Corded Phone
Need to change the ringtone on Panaswonic KX-T7420. How do I do that?
I'm going to guess here, sort of. In the TDA's, it's PROGRAM press the button twice, and dial a number and store. So, in your TD system it should be PROGRAM 99 press the button twice, and dial a number from 1-8 (1 being the default) and STORE
You have to do this from each line and intercom you want to change.
Carl
Feb 11, 2011 | Panasonic KX-T7420 Corded Phone
We have Panasonic KX-T7420 Switchboard but no voice message in the phone system, how do I add that into the system and the cost?
You add a Panasonic brand voice mail system. You can do it yourself, but it's easier to call a dealer. You have to have a specific issue software on your TD phone system and it requires programming, both in the voice mail and the KSU. I charge about $700 for the hardware and programming, your Pana dealer will probably charge about the same.
If you want to gamble, you can probably pick up a used TVS voice mail box for less than $400, but again, there are so many boxes that don't work. As a minimum, a TVA-50 would be best, since it's the current manufacture and it can be upgraded.
Carl
Phone line went down need to reprogram voice, transfer button for panasonic KX-T7420 DIGITAL PHONE
Program 99 press the button and dial 8 165 STORE. That assumes that you're using the default VM access code.
Carl
Feb 09, 2011 | Panasonic KX-T7420 Corded Phone
Panasonic KX-T7420 New arrival in the company.old employee's message is on voice mail, plus I don't have the password. How do I reset?
You log into the system owner's mailbox (999) and follow the prompts to edit the mailboxes. One of them will let you reset the password.
Carl
Feb 01, 2011 | Panasonic KX-T7420 Corded Phone
Panasonic KX-T7420. There are several of these phones in our office, I would like to know how to reset all extension numbers at each phone and create new ones.
Reset? How about you just program new ones over the old? I'm guessing you mean intercom DSS buttons, so you dial PROGRAM 99, press the button and dial 1+ the new extension STORE. Keep doing that to all the buttons you want to program and then pick up the handset and drop it back down again when you're done.
Carl
Dec 23, 2010 | Panasonic KX-T7420 Corded Phone
Need to change password on voicemail extension on
If it's a Panasonic brand voice mail, you administer the system from the System Owner's mailbox (999). With that, you can use option 4 or 5 and reset the mailbox password to any and all mailboxes (except 999 :-)
Carl
Sep 03, 2010 | Panasonic KX-T7420 Corded Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
Just plugged caller id box in to panasonic kxt7420
There is no such thing as correctly plugging an analog caller ID box into a digital phone line.
CID display comes from a TD-193 card mounted in the Key Service Unit and it only displays on Panasonic system display phones designed to work on a TD system. The only system that passes CID through to stations is a TA-824 and certain models of TDA-s that have special analog extension cards.
You can use the analog box, but you have to bring the line from in front of the system to the CID box.
Carl
Nov 11, 2009 | Panasonic KX-T7420 Corded Phone
How do i pre-set an area code so i don't have to dial it every time? The office uses the panasonic kx-t7420 phones. Thanks
What phone system are you using? we will need to know the exact PBX or KSU to help. If your phone is a 7420 could be on a number of units, you will also need a 7430, 7453 or other display phone to program. In some cases this may not be an option or could require programming software by your vender to make work.
Reply and we can take this the next step.
Aug 03, 2009 | Panasonic KX-T7420 Corded Phone
Panasonic KX-T7420 Corded Phone Logo
189 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
