Question about HP OfficeJet 6210 All-In-One InkJet Printer
No printing...? Okay, basically this printer is only a few months old. It copies just fine, so it prints, but when you try to print from the computer, nothing happens. I've checked the connection cable, and all of them are plugged in all of the way. The printer icon comes up in the corner taskbar, with no question mark, so the computer must detect the printer. The only thing odd that happens is that when you command a print, the printer makes a really soft click-click-click noise for a second or two, like it's trying to print, and then it stops. Does anyone know what the problem is and how to fix it?
  • nymec Jun 22, 2008
    When I try to print, it hangs up at the stage "Opening printer connection." Then nothing happens. This takes place even if I connect the Mac directly to the printer with a USB.
Make sure it's 'pause printing' isn't checked on the printer properties
Posted on Jun 24, 2008
Make sure after you click 'print' that the printer you are printing from is not the 'fax'. I had this happen too... just a suggestion ;)
Posted on May 11, 2008
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
Printing nice but very light
the ink may have become very old. i would suggest you to make a refill again.
Jul 30, 2008 | Canon PIXMA iP90 InkJet Printer
HP Photosmart C4490 won't print
teps on how to change jet ink cartridge where do i pull on the printer.
Jun 24, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Msg saying unable to start print job. is printer
Uninstall the Adobe PDF viewer and then reinstall it as the printer is respondingto other print commands,so its an issue with the s/w you are using.
Jun 11, 2009 | HP PSC 1410v All-in-One Printer
My Monarch 9416 203 DPI prints offline
You did not say whether this printer is the same as your others, if it is not then you will have to get the correct software driver for this particular printer.
Jan 08, 2009 | Monarch 9416 (Part M09416-TT04) Printer
I can not print
Cannot print? What you mean? Cannot print from computer? Or basically the printer will not print.
If this is only a printer there is a self test so you can print without using the computer in that way you will know if it still works, if it prints good its on the settings on your computer.
If this is an all-in-one printer why not copy something. You will know if the printer is working fine.
Nov 10, 2008 | Lexmark Office Equipment & Supplies
Kodak 5100 will not print consistently
I am currently having the same problem with a 17" iMac Intel Core Duo.  The printer worked fine for a few months, now it will only print in black and white and sometimes in color that is extremely faded.  I have tried every troubleshooting tip in the book and still no luck.
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Dec 17, 2007 | HP PSC 750 All-In-One InkJet Printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
