Question about Sylvania SMPK8858 MP3 Player
When i turn on the mp3 player it just read loading and begans flashing. What's causing this?
  • 677 Answers
Hi,it's not updated that's why . You need to upgrade with firmware.
Follow this instruction:
Things You'll Need:
  • A MP3 Player
  • A Computer with an Internet Connection
Verify that the player is fully charged.
Verify the the player is unplugged from your computer.
Go to the Mp3 support site, linked below, select your player, and download the Sansa Firmware Updater software. Follow the instructions for installing it on your computer. If you need them, you may also download user manuals for your or watch how-to videos on updating the firmware.
Put the player in MSC mode. Go to the settings menu, select the USB submenu, and then select MSC. Some players with early firmwares do not have the USB options in the menu. If this is the case with your device, then there is another way to force it into MSC mode: Put the device in "hold" mode by sliding the hold switch until orange is visible. Next, press and hold the left (rewind) button until the screen changes. Go to the next step.
Plug your mp3 player into your computer and wait. The Firmware updater should launch automatically. Follow the prompts to update your player. Be certain not to unplug your player until the updater is finished. The software will tell you when it is safe to disconnect.
Tips & Warnings
  • If the above does not work for any reason, there is another way to update the firmware, by manually installing the necessary files. Consult the official support forum for specific instructions for your device. See the link below.
  • Be sure not to unplug your device while it is being updated. This could permanently ruin it.
Posted on Jul 14, 2010
  • vernon_nesbi Jul 15, 2010
    i didn't see a link to downloading the Sansa firmware update software, can you please resend it? thx
  • ikechukwu joshua
    ikechukwu joshua Jul 15, 2010
    How to Update the Firmware of a
    Sansa MP3 Player
    Updating the firmware of your Sansa MP3
    player is easy, and it will correct problems with the original
    software, and even add new features. Follow the instructions below to
    bring your device up to date. If you have any questions
    about the process, please consult the Sandisk website and support forums
    for more specific information. Links to these sites are provided at the
    end of this article.
    Things You'll Need:
    • A Sansa MP3 Player
  • Step 2
  • Step 3
    Go to the Sandisk support site, linked below, select your
  • Step 4
  • Step 5
    Plug your Sansa player into your computer and wait. The
    disconnect.
  • Read more: How
    to Update the Firmware of a Sansa MP3 Player | eHow.com
    http://www.ehow.com/how_2308344_update-f...
    Go to the Sandisk support site, linked below, select your player, and
    firmware.
    the next step.
    Plug your Sansa player into your computer and wait. The Firmware
    Tips & Warnings
    • If
      the link below.
    • Be
I have a sansa mp3 e280 and when i turn it on it says load image failed
i am assuming the image file means the boot loader, the problem is a bad flash can cause this mostly. also note that if you tried to update the firmware you will have to either re flash it. or send to factory for repair. better to not update new components.firmware if this is the case, they often become bricked units.
Dec 21, 2009 | SanDisk Sansa E280 MP3 Player
I have problems with format erros from limewire
Maybe you can check at the end of the music file and make sure they are no other extension. Also, it could be that the mp3 files are encoded into a higher or lower codec which your device cant read. Check properly the files you download.
Aug 18, 2009 | iLO MP3 Player
When i down load music to my 4GB mp3 it takes the music but it does not reads it. it says "file format not supported""
The songs you are trying to load are not in the right format - it won't take iTunes, for instance
Convert the songs to mp3 format and you won't have any problems
Jun 29, 2008 | Philips GoGear Flash MP3 Player
MY NEXTAR MA9336A1S IS STUCK ON THE NEXTAR SCREEN
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Apr 06, 2008 | Nextar MA933A MP3 Player
RCA mp3 H125PA
I know my does that too.
Jan 09, 2008 | RCA Lyra TH1012 MP3 Player
Problem of not been read by my Notebook.
Maybe, They are not in the good USB mode. Go on setting and change it to MSC mode.
Jan 09, 2008 | Coby MP-C7085 MP3 Player
Phillips 8 GB Go Gear
If you clicked "yes" to an Update for your device, then all your songs have been wiped. Firmware Upgrades and Repairs (whether performed knowingly or unknowingly), will delete all songs from your GoGear.
Alternatively, when you have automatic synchronization set up for Windows Media Player, then re-syncing to the device when the songs don't exist on your computer will also cause the GoGear to be wiped. It's a feature of WMP that I don't like.
-Tha Mp3 Doctor
Dec 25, 2007 | Philips GoGear HDD1830 MP3 Player
Stuck
thge hard drive gone bad, so the player won't load anymore, replacing the hard drive is pretty easy and will solve the problem
Aug 15, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Mp3
make sure they are mp3 format and that you are putting them in the mp3 folder and that you are putting them on the card's drive, not the built in memory drive. To find out which is the card drive, take a picture with the card in, and which ever drive has that picture is the same drive you need to put the mp3's in.
Dec 29, 2006 | DXG Technology DXG-305V Digital Camera
Sylvania SMPK8858 MP3 Player Logo
73 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
R Buschy
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
