Question about Xerox XG-91D 19" LCD Monitor
My xerox xg 91d monitor will not power up. I have unplugged the monitor and swapped power cords with other monitors and it still will not power up.
dixibabe82
  • 54 Answers
SOURCE: the connector on the monitor is different than my
Most tech stores have adapters for this kind of issue. Try BestBuy, CompUSA, or Radio Shack. I would call first and describe what two ends you need the adapter for, i.e. 15-pin male --> 15-pin male. If you are trying to connect an Apple device with a PC device, they have adapters for that too.
Posted on Mar 31, 2009
Geekman
  • 32281 Answers
SOURCE: My Xerox XG-91D has gone totally black. No leds
This could be a back-light problem, it can be caused by a faulty inverter board which supplies high voltage to the CCFL lamp or the CCFL lamp is faulty. The CCFL lamp is a mini fluro tube.
Check LCD Parts for service, parts, and DIY info - click on this link to their WEB site :-
www.lcdparts.net
Posted on Oct 25, 2009
budmrtn
  • 11361 Answers
SOURCE: my Xerox XG-91D LCD Monitor start, display
I would try VGA to VGA hook up first to narrow down the problem before start taking the monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). See example of failed monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Posted on Apr 01, 2010
  • 1684 Answers
SOURCE: NO PICTURE
These are great monitors but the power supplies have a bad habit of failing. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/xerox-xg-91d-monitor-repair/ That shows what goes out, how to get to the boards and a full parts list to do the repair. If you don't want to do the repair yourself we do offer a repair service, that information can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions please let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 30, 2010
SOURCE: How do I hook up a DVI-I digital cable to my xerox xg-91d
Does your version of this monitor have 2 female video ports on the back, external power supply, and the ANTI-GLARE coating on the glass???? My version is the much more common one with the DVI-I (not sure if its single link or dual link configuration 'see Wikipedia-dvi connector') cable hard wired directly to the monitor and can plug directly into most all DVI video cards. Originaly I had to buy a vga to dvi adapter to make it work on my Slimline HP.
If it is one of the models from the first production run of this monitor (anti-glare coating on the glass) list it on ebay, I would love to bid on it.
rgc
Posted on Jul 15, 2010
NO PICTURE
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 30, 2010 | Xerox XG-91D 19" LCD Monitor
My Xerox XG-91D LCD Monitor start, display briefly (about 1 or 2 secs) then goes back. any solution in this case? mention that i use with a dvi-i adaptor on a vga graphic card. thx
Apr 01, 2010 | Xerox XG-91D 19" LCD Monitor
Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Mar 18, 2010 | Xerox XG-91D 19" LCD Monitor
My Xerox XG-91D has gone totally black. No leds light up when I plug it in. The power supply is separate from the monitor itself. The power supply led does light up when I plug it in so I know that it is...
www.lcdparts.net
Oct 25, 2009 | Xerox XG-91D 19" LCD Monitor
I have a xerox XG-91D and when i power it up there is no picture and the green light flashes. how do i fix this?
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jun 05, 2009 | Xerox XG-91D 19" LCD Monitor
The connector on the monitor is different than my computer how can it be hooked up the monitor is a xerox xg-91d
Mar 31, 2009 | Xerox XG-91D 19" LCD Monitor
Compatible with macbook?
Yes. if the macbook has DVI out. Do you have the correct adapter? DVI, you can't use the VGA adapter, you need the appel DVI out adapter.
Oct 04, 2008 | Xerox XG-91D 19" LCD Monitor
Logic board for xg-91d serial number E98Z5501032U
I can repair your Main logic board. I do repair work on ebay. my I.D. ecking767. Or search for Xerox under Computer and Networking
Nov 12, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19 in
it look like you need an inverter
Oct 11, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Outback Jack
Outback Jack
Steven's...
Steven's...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
