Question about Dell Dimension 9100 PC Desktop
Amber light that looks like a battery sign is blinking on & off on the front panel
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
The Dell GX620 as well as SX270/280 computers are a few models of many that suffered from Faulty Capacitors on the motherboard which regulate power supply. When they totally fail, about 4-6 of them on the board, the power light will be orange and the system will not post. Other systems also include reaching a BSOD (Blue Screen of Death) before Windows loads, or even random BSODs while running windows.
IF you have decent soldering skills, you can order capacitors from badcaps.net and replace the 2200uF 6.3v caps on the board and the system will start fine.
I have done about 40+ such repairs can confirm with 90% confidence this is the cause of your orange power light and non-booting issues.
Posted on May 27, 2012
    President:
  • 1,901 Answers
A blinking amber Pwer light indicates that there is something wrong with the power. You might check the following:
Make sure the AC switch is in the correct position. (115-US)
Are you getting any fan action or noise?
Is the green motherboard LED ON?
Make sure all you MB connections are secure.
Check (or have someone check) your power supply outputs.
And for reference, here is a link to your computer's Service manual:
http://support.dell.com/support/edocs/systems/dim9100/en/SM/index.htm
Thanks for using Fixya.
Posted on Jul 14, 2010
Blinking Amber Light when power is attached to the unit.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Jul 21, 2015 | Vizio E550VL 55 in. LCD HDTV
How do I fix my Dell computer that keeps blinking amber color light and does not turn on?
You are going to get a range of opinions on this one. Some suggest a new power supply and others more invasivel repairs involving removal of the front panel and soldering!
http://www.tomshardware.com/answers/id-2277673/dell-wont-boot-amber-blinking-light.html
Apr 21, 2015 | Dell OptiPlex Computers & Internet
Blinking amber light
power board problem
Mar 19, 2015 | Televison & Video
Del 320 optiplex orange lite blinks won't boot up
For the Optiplex 320, a flashing amber light with no sound indication can mean 3 things.
1) Your power supply has failed
2) Your motherboard failed, most likely from a bad capacitor.
3) The front panel board (where the power button is located) is faulty or not connected properly.
I've worked with 10's of 1000's of Dell Optiplex's over the past 8 years and the flashing amber light is well known as a tell-tail sign of one of those three failure. Always start your trouble shoot with a PSU tester, then inspect the motherboard for domed or split/leaking capacitors...then on to the front panel which would require another panel and ribbon from the same model.
Jan 25, 2014 | Dell Optiplex GX280 (99301) Motherboard
Dell poweredge t110 server Amber error light on front panel blink one time
Had the same thing happen to me today and in my case it was a code 18 as they come...
It started while I was installing a video card adapter for a dual monitor setup. The solution - I had to simply close the side panel I had left open for testing and then reboot the server. The intrusion alarm went off.
Feb 02, 2012 | Dell PowerEdge T110 Server (GB/2GB)...
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Power light blinks amber and fans not running
A blinking amber light demotes that there is a problem with an installed device like the CD/DVD Rom, sound card etc.
You will need to start troubleshooting and start to remove each removable part until you find out what device is causing the problem. But before you start taking devices out of the computer try this >>>>
Remove the power cord from the back of the tower and remove the side panel to expose the motherboard.
You now need to look for the motherboard battery and remove the battery for 30 minutes.
After the 30 minutes is up put back the battery and the power cord and try to boot the machine up. The battery looks like this >>>
If its blinks then you will have to start removing or just disconnecting the CD/DVD drive, hard drives and any other device that can be taken or disconnected from the motherboard.
Good luck.
Nov 13, 2009 | Dell Dimension 8300 PC Desktop
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
HP Laptop(Compaq nx6310) Lights are blinking
You did not specify if you are talking about the lights below the screen or the ones at the front of the palm rest.
Have a look at pages 1-2 to 1-5 in the HP support manual (link).
The description might help you.
It seems to me that you are talking about the battery light (which is amber when the battery is charging) and the light for the drive (which is blinking when the hard drive or optical (CD/DVD) drive is in use.)
Just as a side note: if your hard drive light is constantly blinking, although the CD/DVD drive is empty AND you are not saving or accessing data - this could be a caused by not having enough RAM installed. In this case, the excessive memory has to be written to your hard drive, which could result in excessive blinking of that light.
Feb 20, 2009 | HP Compaq nx6310 Notebook
Dell inspiron 600`
naa dont worry drivers are getting upset ...when ever u get time just recover the sys
May 28, 2008 | Computers & Internet
Dell Dimension 9100 PC Desktop Logo
230 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
