Question about Canon PowerShot A520 Digital Camera
My front trim ring around my lens has been lost? can this piece be ordered. love my camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
I believe you're refering to the bayonet cap: http://uscamera.com/cm1-2841.htm
Posted on Jul 14, 2010
Where is the aperture ring on d80 Nikon
If you are using an older lens the aperture ring will be close to the camera body when the lens is on the camera. In order to set the aperture with a D80 and older lens you must set the aperture ring to "22" or the highest number on the aperture ring available. For newer lenses there is no aperture ring. You set the aperture by setting the dial on the top left of the D80 to "A" for Aperture Priority. You then set the aperture by rotating the front dial on the right side of the camera under the shutter release button. On older lenses, after setting the aperture ring to the highest number, you then set the aperture in the same manner.
Sep 22, 2014 | Nikon D80 Digital Camera with 18-135mm...
Lost last silver trim ring for the install on my 13W7 Subwoofer. Where could i possibly buy just that one peice?
Call an authorized JL dealer and have them order it from JL. The cost for the first generation W7 13 o-ring and clamp(sold as a set) is $48. The newer AE version (which is the same just different finish) cost $69. SKU # 90242(1st gen) / SKU # 90213(2nd gen)
Mar 28, 2012 | Jl Audio 13W7 Car Subwoofer
Hi, I have a 85/2.8 Sonnar. It has a spot of dirt behind the front lens. How do I open this one up to clean it? Thanks, Bart, Amsterdam
Normally I would advise against opening up a lens to clean it. You are likely to get more dust in than you get out, and it can be extremely difficult to get the bits back together again. However, if all you want to do is remove the front element, without disturbing the aperture mechanism and complex stuff at the back of the lens, then it is pretty straight-forward.
The front element (probably two or more pieces of glass cemented together) is held in place by a retaining ring that can be unscrewed. Often this ring will have two little slots on opposite sides of the lens with which to grip the ring and unscrew it. You won't have a suitable tool for this around the house, so will have to make or improvise. I have got away with using the points of the blades of a pair of scissors, but take great care, as a single slip will put a scratch across the camera lens that is much more serious than a bit of dirt. Sometimes the ring (at least the outer one, which is merely a cosmetic cover) can be shifted with a jeweller's screwdriver in just one of the slots, pushed around the circumference with your thumb. If it has no slots, you can often grip it with a disk of rubber cut from a bike innertube. This may expose a further, more businesslike retaining ring that actually holds the element in place, which you treat in the same way.
Except that I have been disassembling an old lens as I write this, and while struggling with the second ring, the glass of the front element just fell out and landed on the floor. Apparently the second ring holds something else. Oh, dear. At least it didn't break. I expect I may have disturbed the fine tuning of the focus by shifting the second ring, but I would never do this with a lens that was worth anything.
Jan 04, 2011 | Contax Telephoto 85mm f/2.8 Carl Zeiss...
My grandpa needs a new part for his vivitar 55mm. I don't know about cameras so my description may not be great but it is a rubber ring around a plastic piece that screws into the lens. We need to find a...
I think you want a lenshood that is 55mm in diameter (the distance across the front of the lens-what we also need to know is about the lense- what is the wrting on the ring around the very front glass lens? Also, if you l ive near a camera store, take the lens in and they can help you.
May 17, 2010 | Vivitar 35x X3 Telephoto Lens For All 55mm...
New Nikon D90 with 18 105 lens ring broken
the repair is not expensive, should be around $200 or less, provided that you did not damage the internal glasses and mechanics and sensors. You will need a receipt to repair it at Nikon USA, or goto an authorized repair center to get quote.
Sep 04, 2009 | Nikon D90 Digital Camera with 18-105mm...
Pentax Optio S - lens cover rings popped off
I'd be most happy to share with you how I solved my problem with the Pentax Optio S. It took a bit of clever 'problem-solving' thought and inspection. After suddying the design of each piece and the working components of the exposed lens area, I was able to identify which sections worked together appropriately.
And, I think it appropriate at this time that I ask you to purchase one of my plans in order to receive the full benefit of what I learned from my skillful thinking and examination, and thereby successfully repaired my camera.
I look forward to hearing from you.
Jan 03, 2009 | Pentax Optio S Digital Camera
Canon EOS 400D kit lens problem...
It would be very difficult and not recommended to take appart a lens unless you can easily spot set screws around the area that you want to remove. One thing I would try is to lightly push on the broken off edges back and forth to set them up straight in as much a circular orientation as possible. Sometimes when a piece of any ring breaks off the remaining edges are facing inward or upward depending on direction of impact that caused it, and that way they rub against the encapsulating material as the ring turns.
Aug 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Attachment for filter and hood
If you go to the camera store that sells quantaray then they will be able to order you one if they do not have it in stock.
or you can find one on a online auction site.
you need a step down ring. I believe the size of your lens is 58 mm but you could go to any camera store and ask them to verify that. but it should also be stamped on the front of the lens written in white.
if you find 58 mm anywhere on it then I am right. And that means you need a 72 to 58 mm stepping ring.
hope that helps,
Caleb
Mar 04, 2008 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Lens canon 28-135 IS
Need to open Lens?
1. Front Lens Cap- press the two side taps in and pull out.
Rear Lens Cap- twist and pull out.
2. Remove and Repair: Small Phillip Screwdrivers, gloves and mask.
From the rear, the electrical contacts- remove all those
screws. Some screws are locked with clue. Pinch black
plastic ring that is part of those contacts and gently remove out.
Don't brake the electrical contact ribbon cable.
Good lock.
atdlee@netzero.com
at
Dec 23, 2007 | Canon Zoom Wide Angle-Telephoto EF...
Canon PowerShot A520 Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
