Question about Nokia 6300 Cellular Phone
My message alert tone that is set in my profile does not play upon receiving a message... is my software corrupted? or am i just having an error with my theme?
    Genius:
  • 1,456 Answers
Hi there
First check to see if your phone is not on silent, and also check your spund settings to see if your ringtone isnt switched on,also set your phone to vibrate and ring option..
if the issue persists pls try using the original theme of the phone and test it with a message..
if this works then you should change the theme,but if the problem persists.then the ringer of your phone is faulty and it should be replaced..
Posted on Jul 14, 2010
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
No message alert
I dont receive alert tone and vibration when i receive any sms?
Jan 20, 2011 | Nokia E52 Smartphone
Hi I have Samsung B2100 mobile phone. When I receive a message, the sound is so loud. Can you please tell me how to control the volume.
menu/settings/phone profiles, select profile, then choose options at the low left corner of display. Here, you can adjust type of sounds you want and its loudness. Navigate to the right with your central button and here you are navigating downwards: 1. - message alert type chooser, 2. - message alert tone, 3. - message alert repetition, 4. - email alert type, 5. - email alert tone, email alert repetition, and finaly, 6. - alert tone volume. To enter into the submenu, first click direct the central button, and then choose the volume with left or right part of your central button. I am not a perfect english speaker, therefore I hope I was clear enough making this explanation.
Dec 15, 2010 | Samsung B2100 Cell Phone
INSTEAD OF RINGTONE, I GET A SINGLE BEEP
your phones alert tone was set to beep once, to change this go to profile settings then open the activated profile such as general>personalize>message alert tone then now choose the ring tone you want to use as message alert tone..
Jan 30, 2010 | Nokia 6101 Cellular Phone
Mobile phone - message tone alert?
I do not have the phone or the manual...however here are my recommendations from the phones i have owned.
In the phone settings there should be a sound tab. This allows you to select rigntones and alert tones and alarms. Also there are different profiles that you can select ie: Normal- will play ringtones and all audible alerts and alarms...Silent: Will vibrate only and not play any sound ( even though you have selected a certain sound to play)....hope this helps
May 05, 2009 | Cell Phones
No message alert tone
You will need to access Profiles>(Whatever 'Profile' you have defaulted you will need to edit) Use your options button and access 'edit'.
There will be a list of all your features that you customize any sound for. When you seeing Messaging, access that feature and personalize your on alert.
Hope that helps! Thanks.
Mar 17, 2009 | RIM BlackBerry ® 8830 Cellular Phone
MESSAGE RINGTONES FOR THE PANTECH MATRIX
from the start screen press Right Soft Key 'Menu' > 9.Settings > 1.Profiles > Right Soft Key 'Options' (with the 'Normal' Profile highlighted) > 2.Customize. You will now be on the menu for Call Alert and Message Alert settings. Make your desired changes and be sure to save the settings when you have finished.
Mar 02, 2009 | Pantech Matrix Cell Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Nokia 6600 no new message received display
HI Qrasengan,
1) Open the menu, and go to profiles.
2) Enter the general option, and click on personalise.
3) after that, several option appears.
4) some of them are ringing tone, ringing type, ringing volume, message alert tone, vibrating alert, etc.
5) Go to message alert tone and change the tone u want to listen when message is received.
NOte :Only wav or midi formats are accepted as ringing tone. MP3s are not accepted as ringing tones in NOKIA 6600. U need to install a software "mp3 as ringing tone" or "mp2wmaogg.codec" to make mp3 as ringing tone.
If u want that software, send me feedback or reply.
And I will deliver u as email in ur email id.
Sajan(sajwhat_2003@yahoo.com)
May 03, 2008 | Nokia 6600
Nokia 6300 Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
