Question about Sony KDF-E42A10 42 in. LCD Television
Green power light blinks for 1 minute then the lamp light blinks
    Scholar:
  • 41 Answers
When Lamp of the TV has been blown out, the LAMP light blinks in red.
When there is an internal malfunction in the TV, the Power led blinks and there will not be any picture on the screen.
Since, both are happening with your TV, it seems that there is an internal malfunction. Hence, your TV requires service.
You may try the following troubleshooting steps before getting the TV serviced.
Disconnect the Power cord from the Wall outlet and connect it to a different working wall outlet.
Disconnect surge protectors if you are using.
Then try resetting the TV to the Factory default settings to check whether the issue is resolved.
Posted on Jul 14, 2010
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
My Nikon Coolpix S220 camera getting problem. Upon the power switch press to ON the power-on lamp (green lamp)blink for few minutes but the LCD monitor never turn ON. After the green lamp OFF then the...
I cant detect my pics in my laptop from the sd cars. But I can see in my camera when I insert the same sd card. Is there any problem with sd card or any virus effected? How to upgrade the sd card. please help me out.
Feb 01, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Red light blinks
Check the lamp door (with green on) ,.. both green and red blink - bad lamp. Green off, red blinks..Try unpluging for 2 minutes and retry - if no different (sorry, call a service person).
Apr 21, 2008 | Toshiba 43H70 43" Rear Projection...
Sony KDF-E42A10 42 in. LCD Television Logo
152 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
